Stockmanreef
I found the answer to my first question: is the trailing edge installed with the thicker side towards the aft (trailing edge)? Indeed it is based on another post here in the -14 section.
my question here is about the tapering the tailing edge (E-01423) at the tip where the fiber glass tip is installed. The plans state to file down so that it will match the fiber glass. Not sure how to measure this exactly.
Should it just be filed down a bit more than needed so that it can be back filled when working with the fiber glass? Or should I cut the fiber glass as per the plans and put the fiber glass (later section) in place to determine the correct thickness?
thanks
thanks
