I have the Whelen HDACF strobe system in my -7 that has worked flawlessly for over 300 hours since 2008 until this month where one day none of the strobes worked. I checked the switch and the fuse and that I had 12V at the power connector to the power supply and all were fine. Supposedly the power supply makes a noise when powered up and mine was silent. A friendly RV'er sent me an old ebay unit and it did not work either or make a sound.
I bit the bullet and ordered a new power supply which I receeived and decided that I would first plug the power supply into the harness before mounting it to check that it worked, powered it up and had three working strobe lights and everything looked good.
I then disconnected the power supply and mounted it (Vans mount behind the baggage compartment) then reconnected the cables and turned the system on and nothing, no power supply noise, no strobe lights, nada.
Removed the unit, rechecked 12V power available, checked ground continuity, and tried the strobes one at a time with no effect. I then connected the unit directly to the battery to make sure power and ground were good, still no sound from power supply.
Does anyone have any idea what could be the problem, the whelen tech said that an output short would cause the power supply to shut down but when I first tried the unit all the strobes appeared to be working.
I can sent the unit back under warranty but would like to make sure I have checked anything that might solve the problem rather than have another round of the power supply not working or only working for a few minutes, if there is an output short does it blow a fuse inside the power supply or is it a soft fuse that resets?
Appreciate any suggestions.
