Old 04-29-2018, 09:58 PM
Glen P Glen P is offline
Default Bent tabs on elevator and trim tab
I riveted the inboard bent tabs on the trim tab but I'm not sure that I need to rivet the outboard tabs. Any thoughts on this?
Also, the bent tabs on the elevator didn't go well so I ended up making a riblet. Did others that went that route opt for pop rivets?
Thanks a lot for any comments. I don't know what I'd do without this site.
Glen Palmer
Toronto, Ontario
RV-7 empennage complete
Working on QB wings & fuselage
Dues paid July 2018
Old 04-29-2018, 10:09 PM
tgmillso tgmillso is offline
Hi Glen,
I bent the tabs on the trim tab, but made a riblet for the elevator skin as I was too concerned about botching the tab and having to get a new skin. To rivet it in place I used some MK3129-BS rivets. You just drill everything as per usual using a #40, deburr, dimple, then reassemble and open the hole up to 7/64" for the MK319-BS rivet. Having some Mk319-BS rivets on hand during the build is handy. Given that they are oversized, if you ever botch setting a 3/32" solid rivet, and have to drill it out but have opened the hole to much to set another 3/32" rivet, it's handy to set an MK319-BS rivet instead.
Good luck.
Tom.
