Old 04-24-2018, 08:01 PM
Zazoos Zazoos is offline
Default Auto Pilot Servos Dynon
Getting ready to order my Dynon servos, but not sure which ones.
Options are: Standard Arm, Long Arm, or Capstan
Your input is appreciated.
Trent Flemming
Hallsville, TX
Purchased RV6 - Slider Project
Currently flying X-Air LSA and Powered Parachute
Dues Paid 10/2018
Old 04-24-2018, 08:40 PM
titanhank's Avatar
titanhank titanhank is offline
I have two sv32 servos with standard arm in my -6. Dynon recommends the long arm for the roll, but i have not needed it. The dynon ap74/d180works pretty well with elevator servo set at 100% torque and sensitivity at 7. The roll servo set at 50% torque, 2 degs/sec and sensitivity at 5. The autopilot does not hold heading well in bumpy air due to the small tail of the -6 letting the heading wander around. When the ride is smooth, it works good. The nav mode, coupled to an ifly 740, will take you directly to the airport everytime.
Rv-6
0-320/160hp
Dual pmags
Whirlwind 200rv prop
IFR Glass panel
Trutrak Vizion 385 Autopilot
Flightline Interior
Almost rv14 seat mod
Old 04-24-2018, 10:19 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Originally Posted by titanhank View Post
I have two sv32 servos with standard arm in my -6. Dynon recommends the long arm for the elevator, but i have not needed it. The dynon ap74/d180works pretty well with elevator servo set at 100% torque and sensitivity at 7. The roll servo set at 50% torque, 2 degs/sec and sensitivity at 5. The autopilot does not hold heading well in bumpy air due to the small tail of the -6 letting the heading wander around. When the ride is smooth, it works good. The nav mode, coupled to an ifly 740, will take you directly to the airport everytime.
I read it a bit differently....
http://wiki.dynonavionics.com/Servo_...ion_Guide#RV-6
The long arm is on the roll servo and that is what I used. There is a lot more movement around on the roll servo linkage when it is under the seat.
http://www.dynonavionics.com/include...ions_Rev_F.pdf
I made my own brackets but followed the basic Dynon pictures in the above instructions.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-24-2018, 10:33 PM
Jesse's Avatar
Jesse Jesse is offline
What Gil said.
352-427-0285
jesse@saintaviation.com
Old 04-25-2018, 08:22 AM
titanhank's Avatar
Yeap. Typed it wrong.. long arm on roll servo. My short arm works fiine so far, but dynon did send me the long arm and new shear screw for free.. fixed it. Thanks
Rv-6
0-320/160hp
Dual pmags
IFR Glass panel
Flightline Interior
Old 04-25-2018, 09:32 AM
rvsxer rvsxer is offline
Garmin, too, furnishes a long arm for the RV-6 roll servo, which was mounted under the pilot's (or copilot's) seat.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
Manager - Panel Design, SteinAir, Inc.
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 04-29-2018, 12:02 AM
lr172 lr172 is offline
+1
Be carefull here. I am not sure you can get away using the short arm when installed under the seat without getting dangerously close to the roll over point on the servo arm
N64LR
RV-10 in progress
