Old 04-24-2018, 04:41 PM
David Carter David Carter is offline
Default GMU-11 Installation Location?
Hi,
After lurking here for at least a decade, I recently purchased a flying RV-7A with a steam-gauge "4-pack" (no AI or DG) & TruTrak Vision AP. I'm planning to install a pair of G5s & a GMU-11 for now, with plans to move to a G3X panel later.
I've searched the forums, but haven't located any definitive advice on where & how to mount the GMU-11. For those of you who have done this, where did you mount it? Pictures would be a great help.
If mounting in the wing, how did you deal with mounting alignment in the yaw axis? (Pitch axis alignment seems easy.)
Thanks for any & all advice!
David
RV-7A - Slider - N87BP (bought flying in 2018)
2018 Dues Paid
Old 04-24-2018, 06:01 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Search GMU 11
A few successful installs in the fuse
Larry DeCamp
RV-3B flying w/ carb & Pmags
RV-4 fastback w/ Superior EXP 0360 /AFP & CPI
Clinton, IN
Old 04-24-2018, 07:03 PM
Jesse's Avatar
Jesse Jesse is offline
I usually make a shelf between the longerons 1 or 2 bulkheads back from the rear baggage wall.
352-427-0285
jesse@saintaviation.com
Old 04-24-2018, 07:47 PM
RV6_flyer's Avatar
Default Under Vertical Stabilizer
I mounted mine under ther vertical Stabilizer just right of center. Works perfect with no errors in the calibration or interference tests.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-24-2018, 08:04 PM
Surprising. You have a tailwheel, tailwheel spring, tailwheel weldment, steel elevator horns, plus hardware back there.
Can I send you money for a lottery ticket? ;-)
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-25-2018, 02:29 PM
StickNRudder StickNRudder is offline
Left wingtip. Passes the internal testing with flying colors. I used a Garmin general purpose mount which allows for angle adjustment. I chose this location to keep as forward a CG as possible. Itís not much but every little bit helps.
Rick Woods
N5427W == Jack, Hank, Barbara, and Rick Woods.
Flying, but not done, never done.
Old 04-25-2018, 03:08 PM
That's a really good point. My plane is already light in the front (fixed-pitch prop), and anything I can do to keep CG forward is a win.
Any particular reason for left rather than right?
Do you happen to know the Garmin part number for that mount?
David
2018 Dues Paid
Old 04-26-2018, 12:20 AM
Default My take
I plan my GMU11 fori the left wing because I have the roll servo in the right wing.
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 04-26-2018, 07:29 AM
Walt's Avatar
Walt Walt is offline
I've had good luck with the wing locations but I've also had no trouble with the RV7 rear deck location of the GMU22 on the A models.
I also prefer to avoid the pitot heat wiring so i generally use the RH wing. With the GMU using the CAN bus it looks like an easier install by just extending the CAN bus from the right wing roll servo.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 04-26-2018, 07:54 AM
Default Wing tip install question
My gmu11 arrives today. Why donít strobe lights and aileron heim joints cause a problem in the wing ?
Larry DeCamp
Clinton, IN
