Old 04-19-2018, 01:06 PM
gsimatos gsimatos is offline
Default Matco cylinder springs
Guys n
have the dragging caliper issue with the Matco master cylinders. I got the info here for the collars and spring fix for the cylinders so they fully retract BUT McMaster-CAr will not ship to canada or to my broker in Blaine, Wa. Any suggestion who else may have the collars and springs for the mod Didn't see anything on ACSpruce........Thx Gary
Old 04-19-2018, 04:47 PM
thinkn9a thinkn9a is offline
Default Local hardware store with parts drawers?
Just picked up Springs, bushings, and washers at the local ACE hardware store today. There are some of those part way down to Seattle,.. but gotta believe there are some good stores in Vancouver.
Best of luck
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 04-19-2018, 10:03 PM
OK on the scrounge tomorrow here in the Great White North
(Tho the cherrie blossoms are everywhere in Vancouver)
Old 04-20-2018, 07:49 AM
JonJay's Avatar
JonJay JonJay is offline
I would encourage you to fix the issue before adding the springs. Do a search for all the scoop.
Adding springs just covers up build/design error and is unnecessary if you fix the underlying issue. The stock springs are more than adequate and it’s easy to fix your pedal alignment which is typically the cause of them not returning.
Many, many posts here on how to get it done right.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 04-20-2018, 04:33 PM
doesn't seem like there is any binding in pedals but will look again. Puck on caliper definitely not going back on the right caliper tho, will look again thanks
Old 04-20-2018, 04:45 PM
TX7A TX7A is offline
Default Here's a good thread...
http://www.vansairforce.com/communit...ad.php?t=57022
The long bolt being referred to is a single bolt that carries across the two hinge points of the pedal. Normally, there are two short bolts that do this.
Make sure the holes are "clean" and are in alignment.
I used the long bolts and the extra boost springs. No problems so far; no brakes dragging.
Good luck.
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 04-23-2018, 11:25 AM
Raymo's Avatar
Raymo Raymo is offline
Also confirm your brake reservoir cap has a breather hole or sufficient air space for fluid to return.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
