Old 11-14-2016, 09:00 AM
az_gila's Avatar
az_gila az_gila is offline
Originally Posted by wirejock View Post
You will find parts like this throughout the build. Make it a habit to draw centerlines on flanges before first assembly. When a part might be close, draw an edge distance line. Look for the line. It will save you potentially drilling a hole with an edge distance problem.
Buy a C-Thru ruler like this and it makes drawing those center-lines a snap.
6 inch one shown, the 18 inch one is also vey useful.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-14-2016, 10:03 AM
N329JR's Avatar
N329JR N329JR is offline
You can also measure and scale dimensions for feature locations from the drawings. This has worked well for some feature locations in question and can be a valuable reference or at least a check and balance. Good Luck.
RV-6 (Dad's RV)
RV-8 Empennage 90%, Wings 85%, Fuse 0.01%
2018 VAF Gladly Paid
Old 11-21-2016, 06:31 PM
Draker Draker is offline
I ended up doing just that--measured the actual drawing and applied to the scale of the actual part.
Old 04-22-2018, 12:29 AM
nilberg nilberg is offline
I was going to cut off the spar flange for the SB 14-01-31 and decided to check the interference before making the cut.
I fail to see how the flange interfere. There is also good access to set the rivet.
The below picture shows how my modified HS-405. Trimming the spar flange seems completely unnecessary when using the HS-405 modification instead of the new HS-00005.
What am I missing ?
Bjorn N - RV 7 in progress
Katy, TX
http://www.mykitlog.com/N741BN
