Old 04-29-2018, 03:02 PM
Adam W Adam W is offline
Default cowl install question
Thank you in advance to anyone who takes the time to reply here
after much research on the cowl install i dove in. filtering through all the recommended measurements for simulated spacers, the inconsistency between VANs manual and the FAQ on their site i determined I'm going with 2-1/8 spacer and 1/4" spacing between cowl and flange on spinner backplate.
Today i got to it, and with the ring gear on, the spacers in and backplate mounted the cowl just makes it to 1/4" space to spinner flange. there is literally nothing to cut off the aft side. This caused me to be concerned I have already gone wrong?
has anyone found the latest cowls require no aft side trimming. im only referring to the top cowl so far I have not fit the bottom yet
im using the Hartzel 2 blade BA constant Speed.
Adam Wachtel
Thornhill Ontario Canada
Building RV7 #70770
Wings done
Empenage done
QB Fuse done
Finish kit underway
Vans Airforce Dues Paid
Flying Piper Supercub PA18 150
Flying Cessna 414A
Old 04-29-2018, 07:59 PM
RV7 To Go RV7 To Go is offline
Default Cowl
Can't speak to the latest cowls but I had about 2" to cut off the back of my cowls (2008 kit) with the standard extension. I would suggest no less than 3/8" clearance from the back of the spinner to the cowl. Any less and it becomes difficult to re and re the cowl. One of the guys who has built 8 or 9 RV's leaves 1/2" for this reason. I split the difference between Vans 1/4" and his 1/2" and did 3/8" which worked out ok. I had a 4 with a 3/16" gap and it was a pain getting the bottom cowl on and off. FWIW.
Al
Old 04-29-2018, 08:20 PM
Bevan Bevan is offline
Adam,
I don't think you need/want a spacer with a Hartzell CS prop.
Which engine do you have?
Confirm you have 7 not 7A?
I have RV7A with 0-360 and Hartzell CS prop, no prop spacer. I cut a couple inches off the cowl for a 1/4" space between spinner and cowl. I don't have much trouble getting cowls on off by myself.
Bevan
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 04-29-2018, 08:31 PM
Adam, I had more to cut off that what you are talking about. I have a 9a with Catto and spacer, but O-320. Something doesn't sound correct. Can you post a picture or a link to one?
One thing to think about is on the horizontal cut, favor cutting more off the bottom that the top. You will have an easier time getting the cowl off. If you are a TD, then not as much problem, but still worth considering.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 04-29-2018, 09:25 PM
it is a tail dragger, constant speed prop
imscratching my head now!
Adam Wachtel
Building RV7 #70770
Wings done
Empenage done
QB Fuse done
Finish kit underway
Flying Cessna 414A
Old 04-30-2018, 07:34 AM
sahrens's Avatar
sahrens sahrens is offline
Hi Adam,
By using the spacer are you fitting the cowling without your propeller installed? I did it that way on my 7, and to answer your question, I had to trim off about 1.5 to 2.0 inches. But that was a couple of years ago.
Here is how I worked through that process.
http://www.mykitlog.com/users/catego...category=11167
Scroll Down to the first entry and it briefly discusses the spacers.
Scott
RV-7 N818BG
Old 04-30-2018, 07:50 AM
Mark H Mark H is offline
Adam,
I don't think you are alone in your experience. I set up my cowl with 2-1/8" temporary spacers between the starter ring and the spinner backplate, and it worked out just right for a 1/4" gap once everything was installed. I did not have a lot of excess to cut off. Looking at my construction photos before trimming the top cowl, it did not cover all the rivet holes around the firewall, so I'm guessing I trimmed less than 1/4" off the aft side of the top cowl in some areas. Just make sure with starter ring is seated properly, fit the spacers and spinner backplate, remeasure the prop to verify the spacing is correct, and go for it!
Mark Hansen
Indianapolis, IN
RV-7A N896PS
Flying
Old 04-30-2018, 08:38 AM
And make sure the spinner bulkhead is flat on its face (check with a straight edge).
The forming process often leaves a dished shape in the center of the bulkhead which can position the perimeter flange further fwd than nominal.
The RV-14 spinner installation plans (AVAILABLE HERE) are a bit more comprehensive than for the other other kits. Page 44-02 describes checking the aft bulkhead for flatness and gives a nominal dimension between the ring gear and the aft edge of the rear bulkhead flange, that you can use for reference.
Scott McDaniels
Hubbard, Oregon
Old 04-30-2018, 12:27 PM
thank you this has been reassuring and helpful
can anyone comment on the amount they lowered the top cowl to compensate for engine sag?
Adam Wachtel
Building RV7 #70770
Wings done
Empenage done
QB Fuse done
Finish kit underway
Flying Cessna 414A
Old 06-29-2018, 08:05 AM
Wunderon's Avatar
Wunderon Wunderon is offline
Default drilling top hinges
Somewhat related, when drilling the top hinges to the cowl, is it best to hold the ‘slack’ out of the hinge due to the .090 pin‘s sloppy fit, or let it ride in the ‘middle’ of the hinge eyes where it wants to?
Seems like the cowl would end up loose if you don’t hold the hinge separated, but that might make it hard to put on and remove.
Dave Grimmer
RV8 firewall forward
EAA 84
paid 2018
