Old 06-18-2019, 08:19 PM
lon@carolon.net lon@carolon.net is offline
Default Grab Bar for RV-12
The new 12iS comes standard with a "Panel-mounted cockpit handle to aid entrance and exit" -- often described as a "grab bar." The "old" RV-12 doesn't have a grab bar, but I would like to add one to my 12.
Has anyone done that, and if so, how exactly did you do it?
My 12 has dual Dynon Skyview HDX displays and two vertically mounted Dynon Autopilot Control Panels, so there isn't room between the top of the Auto Control Panels and the very top of the instrument panel.
Old 06-18-2019, 09:05 PM
There is no kit per say, but you can purchase all of the parts needed and they will fit your RV-12.
The layout of your panel would obviously have to change because you can't put a handle where panel components are located.
Scott McDaniels
Hubbard, Oregon
Old 06-19-2019, 08:17 AM
Thanks for this. But I’ve searched the entire Van’s Aircraft website, and I couldn’t find the page that offers individual parts for sale, nor a page that shows what parts I’d need in addition to the bar itself.
Old 06-19-2019, 08:33 AM
Not all parts are broken out into the web store.
Some people have downloaded THIS document and then ordered the parts the would need, over the phone through the orders department.
Scott McDaniels
Hubbard, Oregon
Old 06-19-2019, 04:52 PM
Hal-san Hal-san is offline
I have installed the handle in my 12 with no problem, however I do not believe you can install it with your present panel configuration. Parts that you need are:
The handle is part number F-00078
Left side bracket F-00077-L
Right side bracket F-00077-R
Nutplates (2) MS210055L08
you would also need counter sunk rivets and a couple of screws.
Harold Irvine
N912HM RV-12 Flying.
Old 06-19-2019, 08:12 PM
Scott and Harold, Thank you.
Old 06-27-2019, 06:48 PM
Default "Utility Pull" grab bar
"Utility Pull" grab bar for passenger mounted on right side of instrument panel.
Bulldog Hardware Part number: D-440, UPC 035061928765, 6.5" Black Utility Pull
I purchased it at Walmart $3. It is also available at home supply stores.
Gasket material is between handle and instrument panel.
Joe Gores
RV-12 Flying
Old 06-28-2019, 09:24 AM
Joe, Looks good. Two questions:
1. What is the handle anchored to behind the panel?
2. Did you have to remove the panel to attach the handle?
Old 06-28-2019, 03:15 PM
I do not know if it is necessary or not, but I put 1x2x0.63 inch aluminum
on the forward side of the instrument panel behind each grab handle base.
Yes, I removed top cover to gain access to the forward side of the instrument panel.
I used 10-32 machine screws and nuts. The screw holes need to be an inch or
more away from the top edge of the panel to avoid interference with the top cover flange.
The utility pull handle is made of thin steel. It is very light weight, being hollow.
Even so, it seems to be strong enough. Mine required deburring. I suppose
that the handle is made from flat sheet metal that is punched and formed.
Joe Gores
RV-12 Flying
