Old 06-15-2019, 12:55 PM
Kevin Handley Kevin Handley is offline
Smile Rv 12 nose gear nut
Hi all
I have just upgraded my nose wheel fork it seems ( much better ) just a little puzzled because it says on the drawings to tighten the nut to 18lbs but as I was tightening the nut the fork and wheel was for to stiff so I backed of until it felt right then I inserted the split pin (am I missing something)
Your thoughts please
Old 06-15-2019, 01:12 PM
If it doesn't shimmy, then it's OK. If it does shimmy, then tighten it up.
Joe Gores
RV-12 Flying
Old 06-15-2019, 01:51 PM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is offline
Originally Posted by Kevin Handley View Post
Hi all
Why would you not go with the value on the drawing?
Alex Peterson
RV6A N66AP 1600+ hours
Maple Grove, MN
Old 06-15-2019, 06:46 PM
Itís been a while since I upgraded mine, but I recall the critical attribute was breakaway force on the nosewheel, not torque on the nut. As long as you donít shimmy and steering is acceptable I wouldnít mess with success!😁
Old 06-15-2019, 06:47 PM
Oops! I may have misinterpreted the original post.
Old 06-16-2019, 02:44 AM
Thanks for your replyís
Old 06-16-2019, 02:46 AM
Much appreciated your reply
Old 06-16-2019, 02:47 AM
Old 06-16-2019, 06:14 PM
Handclutch Handclutch is offline
Iíve found just a little less than the specified breakaway force, 18 - 20 psi and plenty of grease works really well. Easy to steer and never a hint of shimmy. Wheel balanced as well. When first got mine it was very difficult to turn - too much breakaway force and a scarcity of grease.
Jack
Old 06-17-2019, 10:17 AM
