Old 06-15-2019, 07:42 AM
Jim, the D-180 has the AOA feature. DOWNLOAD the instructions from Van's. The only thing that you need from the instructions is where to drill the hole in the wing for the AOA port. That port is just a rivet which is the same as those used for the static ports. Connect tubing from the rivet to the D-180. A quick connect fitting at the wing root is optional. I ran the tubing along the inside of the fuselage where it is out of sight.
- The wings can stall at any airspeed when in a turn. But they will always stall at the same angle of attack for a specific flap setting.
Joe Gores
RV-12 Flying
Old 06-15-2019, 08:04 AM
Thanks Joe... I think I'll stay with nice quiet solitude and just continue to remain vigilant for airspeed / bank angle. Shallow bank (always) for the base-to-final turn with constant attention to airspeed.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 459
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
Old 06-15-2019, 08:27 AM
DaleB's Avatar
DaleB DaleB is offline
Jim,
I switched to AOA a couple years back. It's really nice to have, especially to build more awareness of one's AOA during more "sporting" flying. I don't miss the old vane-switch stall warning one bit. That said... if you're happy with it, great!
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 06-15-2019, 08:42 AM
So, when you install AOA you removed the stall warning vane?
My friend's one-year old Synergy RV-12 with dual Dynon HDX has both stall warning and AOA. Lots of sirens as you slow for landing...
EAA #499867
Old 06-15-2019, 08:58 AM
No, the stall warning is not removed. Keep both AOA and stall vane. The AOA audio starts ticking as stall is approached, kind of like Morse Code. As the AOA increases, so does the length of the audio tones, from ticks, to dits, to dahs, and to a solid tone at stall. After flying with AOA for awhile, you will wonder how you ever got along without it. One time I made a steep turn from downwind to base and the AOA stated ticking, even though the airspeed was well above normal stall speed. So I relaxed back pressure on the stick.
Joe Gores
RV-12 Flying
Old 06-15-2019, 09:48 AM
I big safety benefit of AOA is in situations that are not normal flight operations.... such as a forced landing after an engine failure.
It can be a high stress situation.... possibly with some last minute maneuvering at low airspeed. AOA could prevent an inadvertent stall.
Scott McDaniels
Hubbard, Oregon
Old 06-15-2019, 01:31 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
At least for me, once I started using AOA all my landings are super smooth. My passengers even think I know what I am doing now.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2019 Dues Paid
www.PuertoRicoFlyer.com
Old 06-15-2019, 10:22 PM
DaleB's Avatar
I did not remove it, but I did disconnect it. Figured I may want it again some day. After the thing tore a hole in another pair of jeans, I think during the next CI we'll remove the vane.
Dale
Omaha, NE
