Old 11-23-2011, 07:37 AM
diamond diamond is offline
Default canopy options on RV-8
What are the non-slider canopy options for an 8, and how much extra time and money would be required to achieve a tip-up or tip-over configuration? Also, if a person bought a quick build fuse, would there be significant changes needed on the fuse, such that in the end there would have been little to no advantage buying the QB vs SB fuse?
Old 11-23-2011, 08:42 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
RV-8 Fastback mods often include a tip-over canopy, like an RV-4's, but the fastback's canopy is cut down in size a fair amount from the standard -8's canopy.
A regular RV-8's full-size canopy is awfully big and bulky to modify into a tip-over, but I guess you could do it if you were really determined.
Having a slider canopy is a big part of the sexy fighter-plane-like aura of the RV-8. Taxiing back to the ramp, after a smooth landing in front of an audience, with that canopy slid back and your arm hanging out over the side is priceless.
Neal Howard
Airplaneless once again...
Old 11-23-2011, 10:47 AM
Stitch462's Avatar
Stitch462 Stitch462 is offline
QUOTE=Neal@F14;598956]RV-8 Fastback mods often include a tip-over canopy, like an RV-4's, but the fastback's canopy is cut down in size a fair amount from the standard -8's canopy.
Having a slider canopy is a big part of the sexy fighter-plane-like aura of the RV-8. Taxiing back to the ramp, after a smooth landing in front of an audience, with that canopy slid back and your arm hanging out over the side is priceless.[/quote]
Agreed on the taxi back option, Joe Cool P-51 driver look-a-like!
However, larger RV "like" airplanes have the tip-over. My only concern would be that big canopy acting like a huge sail in any type winds. no so much tipping the airplane over but being bent beyond limits and cracking/bending something.
Old 11-25-2011, 11:52 AM
SHIPCHIEF SHIPCHIEF is offline
Tip over considerations:
You should have roll over protection, so you may end up with an RV-4 type roll over bar between the seats. The front seat view is better, but the back seater might not like it...
Tip over canopy would allow antenna mounting on top of the fuselage, behind the back seat.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
Old 11-25-2011, 10:33 PM
CraigC CraigC is offline
This is hilarious! For years people wanted a slider canopy on the RV-4. We have now come full circle.
Craig C A&P/IA
Mesa, AZ RV-8 SerNo 82582
Wings/Fuse N18VA Res
Old 11-26-2011, 07:37 AM
olyolson's Avatar
olyolson olyolson is offline
Default RV-8 Canopy
Why in the heck would anyone want a tip over on an RV-8? I fly a -4 and wish I had a slider. I had to make a bracket on the side rail and the canopy to keep it open a bit so I wouldn't roast while taxiing in the summer in Missouri. The problem with that is too much wind blowing your hat off or breaking squelch on the radio every time you push up the power. I would love to modify my -4 to a slider but it looks to me to be quite a task.
RV-8, Flying
Previous airplanes: RV-4, RV-3, Cessna 140, Corby Starlet, Citabria, Vari Viggen
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 11-26-2011, 08:18 AM
Dennis_I's Avatar
Dennis_I Dennis_I is offline
Only reason why im building a Fastback tip over is that i hate the roll bar in front of my forehead on the std RV-8
Dennis Isaksson
Gällivare, Sweden
Grew up with an RV-4
Now: RV-8, Showplanes Fastback. #83218 Under construction,
Tail, Done
Wings, Done
Fuse, Engine and acessory installation in progress.
Licensed Aircraft Engineer
EASA B1 and B2
Old 11-26-2011, 11:01 AM
RidiculousM RidiculousM is offline
What is the weight difference between stock slider and the Showplane canopy?
Mike
Old 11-26-2011, 03:59 PM
dav1111 dav1111 is offline
Super Moderator
Default Instead of a tip over
Instead of a tip over go with a Todd's Canopy slider and delete the slider canopy from the Van's Aircraft ofer.
Russ Daves
Lubbock, TX
Proud to be a Veteran
N710RV - RV-10 Flying
N65RV - RV-6A Sold
N686RV - RV-6A Re-Built, Sold
N742PZ - RV-8 Co-Builder Sold
N-867RV -RV-7 Finish Kit
VAFWWW Dues Paying Member
Old 11-26-2011, 05:38 PM
In my case, the tip over gives 3 very nice benefits.
1 more shoulder room.
2 better forward visibality.
3 better access to the front side of the panel.
If I ever get to do an eight, it will have the ShowPlane canopy.
