Old 06-21-2009, 12:43 PM
acwrench acwrench is offline
Default propeller choice
any comment or suggestions on matching an IO-320 with a fixed pitch propeller? looked at Catto, Warp Drive, Sensenich wood and metal.
Old 06-21-2009, 01:06 PM
Mel's Avatar
Mel Mel is offline
Avoid the Warp Drive. They don't work well on RVs.
I have run Sensenich wood and metal; both good.
Settled on Catto 3-blade; Best F/P prop I've ever flown behind.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 06-21-2009, 01:16 PM
Mel,
what's their after sale support like?
Pat(acwrench)
Old 06-21-2009, 03:16 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Prince or Catto
There are probably other excellent props, too, but I can personally recommend both of these and the excellent people who make them and stand behind them.
H. Evan's RV-7A N17HH 215 hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
my website
Paid $25.00 "dues" net of PayPal cost for 2015 and 2016 and 2017.
Old 06-21-2009, 04:01 PM
Mel's Avatar
Mel Mel is offline
Originally Posted by acwrench View Post
Mel,
Pat(acwrench)
I assume you mean Catto.
After sale support is excellent. When I ordered my prop we weren't sure exactly how much hp I had, since my engine was modified. Craig purposely built the prop slightly over pitched. When I tried it, it didn't do quite what he said it would. I told him I was very satisfied with the performance, but he insisted on my sending it back for rework. Turn around time was about 2 weeks. The prop then performed exactly like he said it would.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 06-21-2009, 07:54 PM
6 Gun 6 Gun is offline
Default prop
we really like our Sensenich metal prop on 0-360 rv-6
Old 06-22-2009, 10:13 AM
Mel,
If I plan to add an ignition or exhaust mod later, something that would change the power output, should that be a consideration when ordering?
What has the maintenance been like on the leading edges? Any special precautions flying in weather?
Pat
Old 06-22-2009, 10:15 AM
Fallalloveryou Fallalloveryou is offline
Default Sensenich Wood prop
I can sell you may almost new sensenich wood prop for $800. It give good performance. You can email for photos ksanders@bellnet.ca thanks Rick
Old 06-22-2009, 12:34 PM
Mel's Avatar
Mel Mel is offline
Mel,
Pat
Typically wood and/or composite props aren't as subject to harmonic vibrations or pulses caused by ignition and exhaust mods that metal ones are. Of course, from a liability standpoint, "you're on your own!" As far as power output, obviously if you increase power, you're going to turn the same prop faster.
I generally throttle back a little in rain although with the leading edge tape, Graig says you don't need to.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 06-22-2009, 07:36 PM
Mel, and all thanks for your input. Emailed Catto props and got the facts from them today. Looks like this install would do well with a 2 blade prop.
Pat
