Old 11-12-2017, 11:53 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Default Dual P-Mag manifold pressure adapter
Anybody know where to get an aluminum dual manifold pressure adapter to connect two P-Mags? I have a plastic one similar to these from an auto parts store but would prefer a metal one instead.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
www.PuertoRicoFlyer.com
Old 11-12-2017, 12:54 PM
rv8ch rv8ch is offline
Default same here
looking for something similar as well. If you have a manifold pressure sensor and dual pmags you need either two Ts or a 4-way adapter, and I've only been able to find plastic ones so far.
Mickey Coggins
http://rv8.ch
Old 11-12-2017, 01:30 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I use the push-in "Y" connectors that are used for pitot/static systems. They are behind the baffles, so the temps aren't extreme, and have worked fine for years. Also makes it really easy to disconnect and blow in a single tube to time both P-Mags simultaneously.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-12-2017, 03:53 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default TS Flightlines
I had TSFlightlines alter my MP line between the #3 cylinder head and the FW with a TEE inserted in the line. He even clocked the fitting for me.
It made a nice install. Ran a seperate black hose from each PMag over to the fitting.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 11-12-2017, 03:55 PM
GalinHdz's Avatar
It sounds like there might be a small market for something like this. Maybe we can get TSFlightlines to make a few metal "T" and "Y" connectors and have them available for purchase. Something like these but in metal.
Galin
CP-ASEL-AMEL-IR
Old 11-12-2017, 04:42 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default This is what I used -
http://www.aircraftspruce.com/catalo...?clickkey=6557
I needed 3 manifold pressure outputs, 2 for the Pmags and another for the MAP sensor.
I mounted one of the "1 IN, 4-OUT" blocks on the firewall. I installed 2 nylon elbows - one for each Pmag, screwed the MAP sensor directly into the block and plugged the unused output port.
When I check the Pmag timing, it's easy to disconnect both lines and plug them into a simple Y adapter that I keep in my tool box.
Rick Aronow,
A&P, iRMT
Flying 7A Slider;
RV-12 (ELSA, Dual G3X), SOLD
Highland Village,TX
Old 11-12-2017, 04:44 PM
koupster's Avatar
koupster koupster is offline
Default Metal Tee Unions
https://www.grainger.com/product/PAR...ebparentimage$
Cheers, David
Old 11-12-2017, 05:19 PM
Galin---we've actually improved on things. Email me and I'll send you a pic.
( Dont know why I didnt think of this before)
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 11-12-2017, 05:32 PM
gasman gasman is offline
If you are going to use a line that can be pushed onto a barbed fitting, what is wrong with a nylon fitting?
VAF #897
2017 =VAF= Dues PAID
Old 11-12-2017, 05:48 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Tom question
Are you stocking these Grainger tees ? Grainger is a little cranky to deal with.
An MAP sensor adds another T and three more failure points. A 4 port metal component as mentioned, would be ideal if anyone wants to build some. Tom built me braided tube from the prime port on #4 with two nipples for Pmags. One with three for MAP also would be perfect.
Larry DeCamp
RV-3B flying w/ carb & Pmags
RV-4 fastback w/ Superior EXP 0360 /AFP & CPI
Clinton, IN
