Old 11-12-2017, 10:20 AM
pilot_tender pilot_tender is offline
Default WTB: Bandsaw
Anyone within driving distance of Indianapolis have a Bandsaw they want to sell? Thanks!
Old 11-12-2017, 10:31 AM
Default Bandsaw
You might check harbor freight. I bought one of their four speed wood bandsaws and converted it to a metal cutting saw. Works great.
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2016,...Thanks DR+
Old 11-12-2017, 10:56 AM
9GT's Avatar
9GT 9GT is offline
Ditto the HF model. I keep that one in my shop and picked up a nice Ridgid floor model on Craigslist that I keep in the hanger.
David C.
Howell, MI
RV-9A: Under Construction
"Donor Exempt" but donated through Dec. 2017
Old 11-12-2017, 06:40 PM
yea, i figured i'd throw out a quick feeler before going out and buying new, but that's my plan!
Old 11-12-2017, 09:00 PM
Jets410 Jets410 is offline
Me too Harbor Freight, $124 plus an $8 aluminum cutting blade (get two, trust me). But my wife has found many-an-item on the various craigslist/letgo-type boards out there.
Good luck!
-Scott
RV-10 N437SB (reserved)
Columbia, SC
Dues paid.
Old 11-13-2017, 08:26 AM
Default bandsaw
I used the bigger 4 speed saw to convert to metal cutting. Nice cast frame and table. The key, though, is a good blade. I went with a Lennox blade. It cuts metal like butter.
Note: I used a 10: speed reducer to get the proper blade fpm for metal...
Bob
Doors - Done
On Gear
290 HP Barrett Hung
Old 11-15-2017, 11:20 AM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Bob, do you have any photos or part numbers? I'm intrigued by what you've done. Been looking at buying a metal cutting bandsaw but they are pricey. Conversion of a wood cutting saw sounds like it may be a reasonable alternative.
Carl - - Morrison, CO
flying by: I give up on predicting!
finalizing the wiring - time for smoke test
No smake - Yay!
Sanding fiberglass - Boo!
paid 'til 10-18
Old 11-15-2017, 02:34 PM
Default Bandsaw
Hi. I used the harbor freight 4 speed bandsaw to start with. I waited for the 25% off coupon.
https://www.harborfreight.com/14-in-...saw-60564.html
Then I used this reducer. I added the mount and motor coupling which you can find on the surplus center.com website. Again, I found coupons online.
https://www.surpluscenter.com/Brands...3-133-10-R.axd
The last thing I added was a quality Lennox metal cutting blade. I think I have about $450 invested, but you would be hard pressed to find a vertical, 14", metal cutting bandsaw for twice that price.
I have used it to cut aluminum, brass, stainless steel, and mild steel with no issues. I use it far more than my horizontal bandsaw.
If you want, I can send you some pix via email when I get out to the shop. Probably be a couple of days, though...
Let me know!
Bob
Doors - Done
On Gear
290 HP Barrett Hung
