Old 11-11-2017, 01:23 PM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default Fuel smell on takeoff
We took our RV-10 on it's second flight today. Both flights were 45 minute long circles around the airfield at 2,400 AGL.
On takeoff, between right when the wheels leave the ground to about 700 ft, I'm getting a distinct and unmistakable odor of fuel in the cockpit. It goes away once I reach 1000 ft, but it's happened both times. Takeoff is, of course, full rich, full throttle and prop governor all the way in. Apart from that both flights have been quite uneventful.
I really want to know where this fuel smell is coming from. We pressure tested the fuel system to 20psi (the most pressure the fuel valve can handle) and it stayed rock solid for days. Anyone else experience this?
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
Old 11-11-2017, 01:51 PM
rvdave rvdave is offline
We’re the tanks full? Fuel vent at wing root? Odor thru aileron push tube hole?
Dave Ford
Cadillac, Mi
Old 11-11-2017, 02:08 PM
Did you check the fuel vent system?
Old 11-11-2017, 02:14 PM
First flight tanks were about 1/2 full. Second flight tanks were completely full. Same smell both times.
RV-10 N1861G
Old 11-11-2017, 03:11 PM
Jasonm Jasonm is offline
I had the same thing happen to me after refueling. Really got my attention! It dissipated shortly after I reached pattern altitude. I attribute the odor to the tanks being full.
Jason McKay
"Phase 1 - 05/26 - 07/02"
2017 Dues Paid
Old 11-11-2017, 03:14 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Either fuel level sending unit or B nut is loose on fuel vent line inside the tank. Open the lower intersection compartment and take a look for stains. If no fuel stains around sending unit, then fill tank and watch fo fuel to flow out of the vent. http://www.vansairforce.com/communit...ight=Fuel+vent
You should not smell fuel even when you over fill the tank..... Here is a good thread to read on a similar issue
http://www.vansairforce.com/communit...ght=Fuel+smell
Bill Peyton
RV-10 - 780 Hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 11-11-2017, 03:56 PM
snopercod's Avatar
One thing I discovered during my Phase I testing was that every single B-nut on the entire aircraft needed re-torquing. Vibration, I guess...
(2018 dues paid)
Old 11-11-2017, 04:49 PM
9GT's Avatar
9GT 9GT is offline
Wrap all your fuel fittings with white tissue or napkin and tape. Take it around the pattern and check them all for the telltale blue stains. It is known that the vents sometimes will purge a bit of fuel and you can smell it in the cockpit. Knowing this I took great care to seal out any air entering from the wing roots by fabricating flexible control rod boots and sealing up any wire/fuel line holes with a little silicone. Never had a fuel smell problem and I always kept the tissue wrapped on the fittings and inspected at every condition inspection.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2018
Old 11-15-2017, 09:22 AM
I think that turned out to be it. The left tank was dripping fuel out of the overflow and leaking in several places, in spite of the fact it was a quick build and these tanks were guaranteed not to leak. In the process of pulling the tank off and sending it back to Vans.
RV-10 N1861G
Old 11-15-2017, 10:07 AM
Jimd Jimd is offline
If you don't keep the ball in the center during climbout and the tanks are anywhere near full and you DONT smell fuel you aren't using all your available senses.
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
