Old 11-09-2017, 08:51 AM
rvdave rvdave is offline
Default Baggage door holder/cable
Looking for a way to control or limit baggage door swinging, banging, or flopping. Maybe a combination spring/cable from baggage forward brace to door? Anyone have a simple setup?
Dave Ford
Cadillac, Mi
Old 11-09-2017, 09:00 AM
Lynnb's Avatar
Lynnb Lynnb is offline
I was planning on doing something similier to a Jeep Wrangler door, where you have a piece of webbing set to limit travel.
https://www.carid.com/2007-jeep-wran...-13906745.html
Picture: (was to large to include)
https://www.quadratec.com/sites/defa...eck_Straps.jpg
There are also kits to install struts like on the doors, but I wanted to be able to easily remove my door.
RV-10 in Process
Old 11-09-2017, 10:51 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Aerosport makes a strut kit for the baggage door. It's attached to the door with a pin that's quickly removable for opening past 90 degrees or door removal (my baggage door is removable without tools due to a hinge modification I made during the build)
It takes me about 30 seconds to remove the door from the plane, even with the strut.
Here is a link to the strut:
http://aerosportproducts.com/rv10baggage.htm
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 11-09-2017, 11:28 AM
Originally Posted by NovaBandit View Post
...(my baggage door is removable without tools due to a hinge modification I made during the build)
It takes me about 30 seconds to remove the door from the plane...
A pic or a description of this mod would be appreciated.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 11-09-2017, 11:38 AM
Electrogunner Electrogunner is offline
Default Door mod
Ed has a very entailed write up and I think a video on their site. I just did the mod the other day. Works very slick, similar to how vans has you make the hinges for the removable rear seat backs.
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Garmin 900x
Whirlwind 3 blade
Emmpenage 99.9999% done
Wings 99.99998% done
Fuselage SB 90.1% done. I think
Fuselage and tailcone is one.
Old 11-09-2017, 08:56 PM
I know there are some inexpensive struts available but I thought I saw somewhere a spring/cable combination. Maybe the strut might be a better way to go.
Dave Ford
Cadillac, Mi
Old 11-09-2017, 10:58 PM
az_gila's Avatar
az_gila az_gila is online now
Question Remove?
I can see an option to open past 90 degrees at times may be useful, but what advantage would it be to make the door removable?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-09-2017, 11:15 PM
One of the challenges (IMO) of the stock door design is that it is tough to attach the door without boogering up the skin (and/or paint), due to how the hinge pin inserts. So, do you attach the door (and booger up the skin) then paint, or do you paint the door off the airplane, and booger up the paint when you attach the door.
Making the door removable and easily re-installable could eliminate the issue.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 11-09-2017, 11:53 PM
az_gila's Avatar
Smile
Thanks for the explanation... my half-made kit already had that part assembled and the door installed with the hinges riveted in place.
Gil Alexander
Old 11-10-2017, 03:29 AM
GregMac GregMac is online now
Keeping in mind your question Dave..... “ anyone have a simple setup” I used a nice bit of marine cord to keep my baggage door from opening past 100* .....Drilled a 1/4” hole about half way across the inside top of baggage door internal skin just down from the top bend. Attached an ally lug (about 2”long) about half way along
the top of the baggage door opening frame with a suitable screw and nyloc, 1/4” hole in other end of lug. Tied a knot in the “nice” cord and with the help of some tie wire, fished it through the latch slot of the door to the baggage door hole. Then did the same knot trick at the other end to achieve the desired opening. Solves the swinging out problem, it’s lite, it’s simple, but it doesn’t fix the “banging or flopping”. Cheers from Western Australia
