Old 11-08-2017, 06:52 AM
bluskydreamin bluskydreamin is offline
Default Dual B&C Voltage regulator install location
Getting ready to install both B&C VRs in the project. Anyone care to share where you mounted yours for ease of access down the road?
Thanks!
Old 11-08-2017, 08:46 AM
rvdave rvdave is offline
Behind the panel the first sub panel but wherever you mount it consider being able to adjust it if you have the adjustable version.
Dave Ford
Cadillac, Mi
Old 11-08-2017, 09:40 AM
bruceflys bruceflys is offline
As my first subpanel was full, I placed two 3/4 X 3/4" angles fore-and-aft between the subpanel and the panel. The two VRs rest on and are attached to the angles with screws. B&C recommends vertical orientation, but to me solid state power electronics do not care which way they face.
Bruce
RV-14 - Empennage Kit Started
RV-12 - Parting Out
RV-10 - Project Sold
SeaRey - Flying 2012; Sold 2017
2018 Contribution made
Old 11-08-2017, 03:27 PM
Richard Connell Richard Connell is offline
Iíve been thinking about this a bit as well.
I have an 8yo flying RV7 which I built and also did a complete panel refresh around 4y ago. Iíve spent a lot of time maintaining and ďtinkeringĒ with it over this time so now that Iím building the 10 fuse I find myself continually assessing the build from a future maintenance perspective.
For example I have vowed that there will be nothing forward of the sub-panel on this plane.
I currently have a dual B&C alt setup and will likely replicate that in the 10.
Iím looking at all that space under the front row seats thinking it must be useful for all sorts of things. ADHRS / voltage regulators / busses etc.
Has anyone used this space like this? Super easy maintenance access it would appear at first glance.
Cheers
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 11-08-2017, 04:42 PM
Default And..
And your fuel line(s) run through there as well!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 11-08-2017, 08:41 PM
vernon smith's Avatar
vernon smith vernon smith is offline
Default and
Yes, and it all co-mingles in the tunnel
Old 11-08-2017, 11:03 PM
I hadnít considered the fact that there were fuel lines there.
After all there are plenty of places in the 7 where there is co-located
fuel lines and wiring.
At the margin though I can see more risk with having exposed terminals on a fuse block or the like than contiguous wires running through the area.
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 11-09-2017, 05:50 AM
Default Location considerations
Thanks for the input guys. I was not considering the need to adjust voltage as I should have. The vertical mount suggestion from B&C may be a consideration for moisture / condensate dripping for the wiring.
The under seats location could be good real estate if your mounting components under the upper seat pan as long as you have a drip loop in the wiring.
Old 11-09-2017, 08:03 AM
Bill Boyd's Avatar
Default Indeed
...and fairy neutral from a CG perspective, if you're obsessing about that sort of thing.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 11-09-2017, 09:57 AM
DRMA DRMA is offline
Originally Posted by bruceflys View Post
. . . B&C recommends vertical orientation, but to me solid state power electronics do not care which way they face.
While the chip may not care, there may be a thermal cooling reason for the orientation. If there are heat sinks on any of the electronic devices, the orientation of the heat sink with regard to vertical can impact the ability of the heat sink to dissipate the surplus heat.
I'm not saying that is the case with the B&C regulators as I don't know if they have heat sinks, but it might be a reason for the orientation recommendation.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2018 VAF Dues Paid
Last edited by DRMA : 11-09-2017 at 09:59 AM. Reason: improved readability of sentence.
