Old 11-04-2017, 04:32 PM
Default Make RV-12 Cabin More Habitable in Winter
The weather is getting cold and I decided to tackle the problem of cold air passing forward from the baggage compartment.
The solution consists of one piece of sheet aluminum, two pieces of cardboard, and three pieces of foam. The RV-12 seat backs are aluminum frames with 1” angle sides that contain the upright upholstered cushions.
I made an aluminum sheet 18”H with 1” flanged sides to block the air between the two seat backs. The 1” flanges tuck between the seat frame and the seat cushion. The piece of aluminum is tapered something like 3” wide at the top and 5-1/2” at the bottom. The two side baffles are similarly 18"H with 1” flange but made from cardboard. The outer cardboard edge is taped to the roll bar with blue painters tape.
All three baffles use foam on the bottom to seal against uneven bottom seat cushion and yet not impinge on the seat belt anchors or the central flap handle. The baffles at made from 3” foam and each is 6” high. You will have to custom measure/trial for width.
So how does it work? Today I flew with 35F OAT and the only air movement I noticed was from over the top of the seat backs and even that amount of air was slight. I would say it works very well.
Below is a poor sketch. I will take a few photos next time I fly.
Hinckley, Ohio
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 397
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 11-04-2017, 05:46 PM
mwardle7 mwardle7 is offline
This is a great idea. I look forward to seeing how it works!
I am hoping to order the landing gear leg-to-fuselage fairings for the new RV-12IS when they become available. I am hoping the the fairings will stop the cold blast behind the seats.
Old 11-04-2017, 07:29 PM
I installed gear leg/fuselage fairings and it didn't stop air ingress. See http://www.vansairforce.com/communit...12&postcount=5.
I think air comes in through the spar openings. My theory is if you contain the incoming air behind the seats then the venturi effect of the tail cone will extract the incoming air through the corrugated openings on the edges of the rear baggage bulkhead.
Hinckley, Ohio
EAA #499867
Old 11-04-2017, 07:43 PM
rk2436 rk2436 is offline
A couple of shop towels stuffed in the spar openings works wonders for the wintertime. Easily removed for summer.
Old 11-05-2017, 02:15 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Hey...thatís too easy. Us guys like the more involved approach that requires bending metal etc.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 11-05-2017, 05:53 AM
I have not tried this yet, but thought of injecting Great Stuff Foam into plastic bags that have been stuffed into gaps.
Joe Gores
RV-12 Flying
Old 11-05-2017, 03:15 PM
Handclutch Handclutch is offline
I had quite a gale coming in behind the seats. Turned out to be the gaps around the spars. I RTV'd foam strips about 1.5" to 2.0" square to each side of the spars so that they compress against the fuse when the wings are pushed in. Solved the problem.
Jack
Old 11-05-2017, 04:13 PM
Dave12 Dave12 is offline
Jack
Any pictures?
Wag Aero Sport Trainer
N588DF RV12 #336 Sold
N73DF RV12 #244 Flying
Rans S21 Outbound (Coming soon)
Old 11-06-2017, 03:52 PM
Unfortunately, I didn't think to take any. Will get some next time the wings are off but that doesn't happen any more than necessary - could be a while.
Jack
