Old 10-30-2017, 08:23 PM
RandyAB RandyAB is offline
Default Quick build fuselage factory mistake?
I'm going through the quickbuild fuselage step by step in the instructions checking the assembly. Today I noticed that the aft holes in the mid fuselage bottom skin were drilled and dimpled at the factory. The plans explicitly state to leave these holes alone until the tailcone is assembled in section 32. Has anybody else experienced this and is this going to be a problem?? I wouldn't worry about it so much other than the fact that the joint between the fuse and the tailcone is kind of a critical one. Thoughts?
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 10-30-2017, 09:39 PM
Is the problem just on the flat skin(s) or does it extend around the curves and up the sides? If it is just on the flat portion, no problem at all. If it goes up the sides, it'll be a little more work, but should be manageable.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 10-30-2017, 10:24 PM
Just the bottom skin.
Randy P.
1st time builder
2017 dues paid
Old 10-31-2017, 06:10 AM
soloff soloff is offline
I think you are referring to the last 2 rows of rivets on p26-8, Figure 1. I just checked my QB Fuselage this morning and they are not dimpled.
My Fuselage was shipped out the same day as yours so it looks like there are differences for each one built. I found a number of other differences compared to the plans that Iím working with Vanís on. Iíll post them in a couple days after I get feedback from Vans.
Scott
Working on the RV10 Fuselage
Build Log - www.oloff.com
2018 Dues Paid
Old 10-31-2017, 09:28 AM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Keep checking!
It is NOT UNCOMMON to find mistakes/omissions in QB kits.
Assume NOTHING!
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
2018 Dues Paid
Old 10-31-2017, 09:36 AM
My Fuselage was shipped out the same day as yours so it looks like there are differences for each one built. I found a number of other differences compared to the plans that I’m working with Van’s on. I’ll post them in a couple days after I get feedback from Vans.
Thanks for looking Scott. I'm very interested in the variances that you found. I'd like to check mine.
Randy P.
1st time builder
2017 dues paid
Old 10-31-2017, 09:40 AM
Assume NOTHING!
Truthfully I'm perturbed to find such a basic error. I'm not sure what assumptions you are referring to. What I did assume was that they were experienced builders and would build it per plans.
Randy P.
1st time builder
2017 dues paid
Old 10-31-2017, 09:45 AM
I can absolutely see how it would happen. Guy starts dimpling a sheet, forgets to stop when he needs to.
I've done similar things myself.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 10-31-2017, 09:51 AM
AAflyer's Avatar
Unhappy Perturbed!
Randy,
I was VERY perturbed to find mistakes, for I, too assumed they were pros that would 'take care of me', and deliver a "finished" product. Not only were there some omissions and mistakes, I was extrememly frustrated that their assumption that I would paint my plane resulted in gross scratches all over the parts. They deburred rivet holes with sandpaper!
Bruce Windom
QB RV-8 N148BW
2018 Dues Paid
Old 10-31-2017, 09:56 AM
I can see how it can happen too if you don't tape over the holes that are to be left untouched. The simple solution is to use the tape.....
Randy P.
1st time builder
2017 dues paid
