Old 10-30-2017, 11:42 AM
Thunderpig Thunderpig is offline
Default DRDT adjustments
Originally Posted by Thunderpig View Post
Just posted a couple pictures of my about to be finished -10 HS and I am getting some comments on how I may not be "aggressive" enough. I am using an Experimental Aero dimpler with a dimple die set from Cleveland. Will try to get some pics posted on here...all arrows and suggestions are welcome.
Main question is, is there a difference in the die sets and just how tight can one go when dimpling. Not wanting to cause stress cracks...I am currently deburring and priming before dimpling.
http://cubeupload.com/im/Thunderpig/IMG0172.jpg
http://u.cubeupload.com/Thunderpig/IMG0173.jpg
http://u.cubeupload.com/Thunderpig/IMG0174.jpg
http://u.cubeupload.com/Thunderpig/IMG0175.jpg
http://u.cubeupload.com/Thunderpig/IMG0176.jpg
http://u.cubeupload.com/Thunderpig/IMG0177.jpg
This is a copy of a post I made in the Tools section...anyone have a DRDT and is there anyway to make these dimples more properly defined?
Old 10-30-2017, 11:47 AM
Nova RV Nova RV is offline
More pressure, a lot and they will form nicely. There is a video by Cleaveland tools on dimpling and getting crisp dimples. I watched it and went right to the shop and added a lot of pressure from my DRDT and the dimples improved 100%
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 10-30-2017, 11:54 AM
FloMo14Builder's Avatar
FloMo14Builder FloMo14Builder is offline
Default Pressure
Yep, I used a lot more pressure to the point that the DRDT arm deflects noticeably and I now get crisp edged dimples.
FloMo14Builder - KG5VAC
Shop - Complete
Practice tool box - Complete
Practice Airfoil - In progress
Emp Kit - Ordering Soon
Old 10-30-2017, 12:38 PM
Question is...is this a show stopper? I clearly haven't made perfect dimples, but structurally, I don't see a huge issue.
Old 10-30-2017, 01:34 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default 1 turn preload
My horizontal stab was just a bit "underdimpled" until I zeroed in on how to set up my DRDT-2. I was concerned at the time (cosmetically, not structurally) but it turned out to be a non issue.
I used 1 turn pre-load for all the rest of my build - worked great! 1 turn pre-load defined as one additional turn of the adjustment screw from the point where the two bare dies touch each other (no material between the dies). As others have pointed out, in use there is a noticeable deflection in the upper arm of the tool when dimpling.
You might take a look at this post http://www.vansairforce.com/communit...07&postcount=3 that I made back in 2009. It has photos of test dimples I made with the DRDT-2 and pneumatic dimpler using different preloads.
Dan Langhout
2018 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
296 hours and counting . . . .
Now based at Moontown (3M5)
Old 10-30-2017, 01:57 PM
BrianDC BrianDC is offline
No, this is not a structural issue, but a cosmetic one.
Agree with the others that your dimples appear to be slightly under dimpled. Honestly not a real problem, just a "look" thing.
Here is the cleavland tool video being discussed:
https://youtu.be/Qo9QCMaNSoA
Brian Lester
RV10 - #41778
Empennage - Done (for now)
Wings - in progress
RV10builder.com
Old 10-30-2017, 02:34 PM
wirejock's Avatar
wirejock wirejock is offline
Default Structural
Just a little point.
It shouldn't be structural but if the dimples don't nest in the substructure and parts have a gap, it can be structural.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 10-30-2017, 03:20 PM
Good point, but not specifically a symptom of a consistently under-dimpled parts. Inconsistent dimpled parts would show this behavior, or insufficient countersinking.
Gahhh!!!! I'm no expert, I just play one on the internet, and why I suggested an EAA counselor give a visit in the other thread.
Brian Lester
RV10 - #41778
Wings - in progress
RV10builder.com
Old 10-30-2017, 03:33 PM
wirejock's Avatar
Default Good point
Yes. Exactly. I should have made that clearer.
Larry Larson
Estes Park, CO
Disclaimer
Old 10-31-2017, 09:09 PM
MJarreau MJarreau is offline
Default What is Preload?
I'm not exactly the most mechanical person in my family.
Ok, so I just re-read Dan's post. Does "one additional turn" mean putting the dies closer together?
Thanks!
RV-10 Emp Kit! Here we go!! Woo-Hoo!!!
DUES REMINDER: DEC 2017
