Old 10-27-2017, 02:00 PM
Ron B. Ron B. is offline
Default CO detector
Having less than 100 hrs. on my RV-14A my CO detector gave up. I received a call asking if I wanted to purchase another one at a discounted rate but with less than 100 hrs. on the original one I declined. I asked if they had determined the cause of the failure and they answered premature sensor failure. Sounds like a defect to me, but oh well. Is this a detector's standard life one can expect or am I the unlucky one? These things are quite pricy for what they are but I'm not prepared to purchase one every year. They are supposed to last five years then they need to be re-calibrated and that is bad enough. Cessna's have flown for years I guess I'll have to agree with a Cessna freak" if it's good enough for Cessna it's good enough for me"
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 10-27-2017, 02:31 PM
SmilingJack's Avatar
SmilingJack SmilingJack is offline
Mine has to be replaced...I have 7 years on it and it has worked perfectly!
But, I share a simliar frustration about price and product.
My CoGuardian model I purchaed 7 years ago is no longer avialable and they can NOT recalibrate it. Not sure why...they build it, why can’t they just replace the guts???
Now, I wouldn’t object to replacing it with new, but my unit is bigger then the new ones they offer so I would have to rebuild my side panel to make the smaller one fit.
John Mastro
RV-8
Old 10-27-2017, 03:13 PM
tgmillso tgmillso is offline
Default Model 300 Pocket CO detector
Anyone managed to tap into the alarm output on one of these and wire it into an input on an EFIS (I'm thinking G3X) so you can get a visual warning and audible warning in the headset? Maybe a lower cost solution to our integrated CO detector problem.
http://www.aircraftspruce.com/catalog/pspages/co300.php
Tom.
Old 10-27-2017, 06:28 PM
maus92 maus92 is offline
Tom.
No, but I integrated my CO Guardian into my G3X MFD. Requires a RS232 line, but the configuration is simple, and the PPM can be displayed on the menu bar if you like.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 10-27-2017, 09:30 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Tom.
I wired a CO2 Guardian to provide an external alarm input to my DYNON SkyView. It provides a visual and audible alarm whenever the threshold is reached. You can also use the <TEST> button to mark a particular time on the EMS data file that SkyView constantly monitors and records. VERY useful for troubleshooting issues and identifying EMS values at a certain point of a flight. You can see it on the far right side of the panel.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
www.PuertoRicoFlyer.com
Old 10-27-2017, 09:43 PM
lr172 lr172 is offline
Tom.
Should be pretty easy for the GRT. Solder a wire on the appropriate piezo or led lug and run it to a transistor. You would probably need a 5v power supply for it. Run the output to one of the analog inputs on the GRT. I believe there are various alarms that can be configured for those, but can't recall for sure.
N64LR
RV-10 in progress
Old 10-27-2017, 10:53 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Originally Posted by GalinHdz View Post
I wired a CO2 Guardian as an external alarm input to my DYNON SkyView. It provides a visual and audible alarm whenever the threshold is reached. You can also use the <TEST> button to mark a particular time on the EMS data file that SkyView constantly monitors and records. VERY useful for troubleshooting issues and identifying EMS values at a certain point of a flight. You can see it on the far right side of the panel.
As I read their literature, it says
"The 353N-201 is specifically designed to integrate with and report on the Dynon SkyView line of PFD and MFD displays for homebuilt aircraft. Both alerts and CO levels can be displayed."
and it appears that they are claiming that it can be reset/tested from the Skyview, thus obviating the need to cut a hole in the panel (kind of reading between the lines in the User/Install manual).
I'd *love* to have this *if* it's as they say, but there's nothing about it in the Dynon docs. (I did post this question on the Dynon forum, as well). Has anyone done this? Is this correct?
Old 10-28-2017, 05:44 AM
Thanks Larry. I was thinking something along those lines. I guess I'll be the guinea pig and give it a shot. I'll probably feed it into my GEA24 or GAD27.
Tom.
Old 10-28-2017, 06:02 AM
Smile
hey, I think there is room for one more GPS screen on the upper left.
Old 10-28-2017, 07:13 AM
GalinHdz's Avatar
I know you can hide the detector behind the panel but not sure if the newer units can be controlled by SkyView. I did my installation in 2013 and could not do the TEST from within SkyView. That is why I mounted it in the panel so I had easy access to the <TEST> button.
NEVER enough "gadgets".
Galin
CP-ASEL-AMEL-IR
