Old 10-27-2017, 01:58 PM
bkervaski's Avatar
bkervaski bkervaski is online now
Default Page 46A-10 Wheel Fairing
On page 46A-10 it says:
Mark screw locations on the U-01431-L & -R Nose Wheel Fairing Bracket flanges as per Figure 1. The marks will be visible through the wheel fairing.
My fairings are solid gray, assuming they are newer as I've seen pics of some that are a bit transparent.
If that's the case then I guess I can go ahead and finish the U-01431 with nut-plates and then mark from the inside to drill the fairing holes?
Progress: Away for PAINT
Old 10-27-2017, 06:14 PM
MED MED is offline
You should have received a bag of magnetic balls. (Bet you didn't know what those were for!) Use those to find the location to drill through the opaque fairings. I haven't done it yet, but I found the instructions and it looks doable.
MED
140236
N435MD reserved
Old 10-28-2017, 12:57 AM
control control is offline
http://www.vansairforce.com/communit...d.php?t=134448
Another solution in the link above
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 10-28-2017, 09:46 AM
Instructions are in section 5 of the construction manual.
Scott McDaniels
Hubbard, Oregon
Old 10-28-2017, 12:06 PM
bkervaski's Avatar
Hunting around on the Van's website .. my section 5 is dated 2015, assuming I have an old one since there's no mention of it (and some of the other references haven't quite lined up) .. anyone know where to download an updated version? The only one I can find on the website is from 2013.
Old 10-28-2017, 12:42 PM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Vans aircraft
Vansaircraft.com. Support. rV14/14a. Revisions. Section 5. Dated 2017
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 175+
2018 Dues Paid
Old 10-28-2017, 02:13 PM
Close, but actually is Support/Service and Revisions/RV-14/Section 5
A direct link - http://www.vansaircraft.com/pdf/revisions/RV-ALL_05.pdf
Where on the web site did you find a version dated 2013? (I will get it removed)
Scott McDaniels
Hubbard, Oregon
Old 10-29-2017, 06:54 PM
bkervaski's Avatar
Scott --
The revision I found was here - https://www.vansaircraft.com/public/...uction-faq.htm
I just jumped right in and noted the first few pages I saw had 2013 revisions but there are other years including 2017 in there so it must be the latest one.
Thanks for the help as always!
