Old 10-27-2017, 11:21 AM
JDA_BTR JDA_BTR is offline
Default Canopy gap
Fitting the canopy I get a gap here in either side. Is that expected? Does the fairing layup catch that later?
Second question is about the forward canopy line. My best fit to minimize the side air gap and have no left over rear canopy to trim is with the forward canopy 1:16 or so forward of the forward canopy line. How critical is the forward position?
N1463 seems a good number....
Old 10-27-2017, 12:48 PM
Yes, the FG lay-up covers that gap.
Drifting 1/16" fwd at the front wont cause any problem.
Scott McDaniels
Hubbard, Oregon
Old 10-27-2017, 01:49 PM
Got it. When I sand forward if this area to make the surface fit the fuse do I need to worry about fine sanding it? Or is the bonding going to relieve the need for that?
Old 10-27-2017, 02:57 PM
For clarification, please define "this area" and "the surface".
Scott McDaniels
Hubbard, Oregon
Old 10-27-2017, 03:34 PM
The area forward of point Oscar figure 2 page 38-22
Old 10-28-2017, 09:54 AM
Sorry.... no access to plans at home so I can't help based on that.
Maybe someone else can.
Scott McDaniels
Hubbard, Oregon
Old 10-28-2017, 03:50 PM
Its the area forward of the notch in the picture; it is sanded to smooth the transition of the window onto the forward aluminum surface. No mention is made anywhere of needing to polish it with fine grit paper like is discussed with the edges.
Old 10-28-2017, 03:59 PM
Ok
All edges of the canopy should be finish the same way regardless of whether they get a fiberglass lay-up over them or not.
Scott McDaniels
Hubbard, Oregon
