Old 10-26-2017, 09:16 AM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default What are these, and where do they go?
Like finding Waldo >
These two aluminum strips, each 29 1/4 long, 5/8 wide, 0.018 thick; may have originally come attached to each other and had to separate. They are now primed and the part numbers removed. There are 15, #27 holes equal spaced 2 O/C and about 1/16" off center down the strip's length. The holes align with the forward 15 holes of the 16 holes each side of canopy frame part C-01419-L&-R. They align perfectly with the zone 2 screw tighten sequence called out > RV14 Finish Kit, pg 38-27 figure 4. I have scoured instructions and cannot locate or identify. They would fit perfectly in the canopy frame there but no instruction that I can find to put them there.
I have also looked through the Fuselage manual, as well as the packing lists for a description that would match, NO FINDY.
The clouded highlight identifies the holes that align perfectly between the C-01419-L part and these strips.
EDIT 11:30am > I think I just found them >> Page 38-22, Steps 7. and 8. (Figure 3.); 'USE C-01423 IF REQUIRED". Shims if canopy thickness is less than needed.
Jeff Warren
Simpsonville, SC (SC47 - 10nm NW Triple Tree, SC00)
1946 Bellanca Cruisair 14-13-2 (72 YRS OLD 8/15/18)
RV14A (N14ZT), Ser#140195
Start 10/11/14
Dues paid 12/1/17 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
!! I SURVIVED RIPON ARRIVAL - KOSH 7/21/2018 !!
Old 10-26-2017, 09:22 AM
Nova RV Nova RV is online now
They go between the canopy plastic and the side frame pieces "if" the space between the canopy and the side frame is above a certain value. It keeps the sides from pulling on the plastic.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 10-26-2017, 09:34 AM
jeffw@sc47's Avatar
Default If needed?
Thanks, I did discover them in the interim.
Is there another indication of the canopy rail "needing" the spacers? Will something look like it's binding or buckling?
The canopy thickness is right on, but are there other indications that the shim strip may be needed?
Jeff Warren
Start 10/11/14
Old 10-26-2017, 04:36 PM
Tom023 Tom023 is offline
Interesting. My canopy shims didn't have holes in them, they got match drilled with the canopy in place. My canopy was equal side to side just a bit under the limit at .15 thus requiring the shims.
RV14A #140083
Wings, empennage, fuselage and finish slow builds completed. Avionics and engine installed.
Down to last 90%.
2017 Donation
