Go Back   VAF Forums > Model Specific > Rocket
  #51
Old 11-14-2017, 12:37 PM
Toobuilder's Avatar
Originally Posted by vfrazier View Post
Got any photos? We'd all love to see exactly what you've done!
Not assembled yet, but it is almost an exact copy of the RV-8 design. My main execution change was dumping the nylon pillow bearings in favor of spherical bearings pressed into the ends of the torque tube. I also upped the torque tube OD to 1.125, and reversed the actuator (motor is at the top on mine).
I'll post pictures when it's assembled.
Michael Robinson
______________
RV-8 - Flying
Old 11-14-2017, 07:47 PM
Toobuilder's Avatar
OK, I threw the parts together and snapped a picture.
As with the -8, the torque tube runs behind the back seat and the arms go forward. The torque tube itself is a simple weldment using stock I had in the shop. As stated above, you can see the bearing brackets I made from angle extrusion. The axle is a Hi-lok fastener. The brackets bolt to the lower longerons, and the spherical bearings allow the splay. I had to make new link arms from tubing, and despite the fact that they are longer than the solid aluminum rods that were there before, are slightly lighter. I dumped the lower link joints (with the integrated stud) for normal through bolted units so I could use a larger diameter (0.750) spacer for better load carying ability. The stock actuator was set up for the motor to mount horizontally, so I fabbed up a link to change orientation. The upper mount bolts to the rear seat bulkhead next to the pasenger's left shoulder, and a simple clip ties it into the upper longeron behind the bulkhead.
Like I said: less parts, much beter geometry, stronger, lighter, ....much gooder!
Michael Robinson
______________
RV-8 - Flying
Old 11-16-2017, 08:23 PM
logansc's Avatar
logansc logansc is offline
Mark and the rest of you smart Rocket guys: Finally got around to trying to configure the W&B kernel in my ForeFlight software. It asks for two things I don't understand:
1. The "unique" weight associated with the forward CG point and,
2. The "unique" weight associated with the aft CG point
The forward and aft CG moment arms I know, but unique weights associated with them? Don't think I've ever heard that one.
Lee...
Lee Logan
Ridgeland, SC (3J1)
F1 Rocket #160 flying
Old 11-21-2017, 03:04 PM
vfrazier's Avatar
vfrazier vfrazier is offline
The what???
Did the Foreflight forum offer any clues?
Lee...
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
Old 11-22-2017, 12:18 AM
logansc's Avatar
Vince: I'm with you; I don't get this at all. I really don't know what they are looking for.
Lee Logan
Ridgeland, SC (3J1)
Old 11-22-2017, 01:37 AM
madhun madhun is offline
The AvPlan version is equally confusing but a quick email to AvPlan and they will set it up.
Weight x Arm = Moment
Basically what it's asking is for the fore and aft CG limit weights.
Quentin Carter
Bushby Mustang II - 170hrs and counting
$500, if Mrs. Hun ever asks aircraft parts are $500!
Old 11-22-2017, 07:36 AM
vfrazier's Avatar
Why don't they just say so!?
Vince Frazier
www.f1aircraft.com
Old 11-22-2017, 02:49 PM
Michael White's Avatar
Michael White Michael White is offline
Because that would be easy....
Moose
VAF #136
N424LZ Reserved
Old 11-27-2017, 06:54 AM
Toobuilder's Avatar
Finally got the new flap mechanism installed and rigged. Added doublers to the floor to clean up the flap rod penetrations. Just need to add the cover panels to keep the rear occupant and associated "stuff" clear of the linkage as it articulates.
Looks like I will lose about 1/3 of the left side pocket volume when I close out the motor, but that's still 2/3 better than the RV-8.
This shot shows the vastly superior geometry compared to the Rocket/RV-4 setup. Flaps "up" in this shot.
Right side will not lose any pocket volume, as the cover plate will be below.
Flaps full "down" in this shot.
Michael Robinson
______________
RV-8 - Flying
Old 11-27-2017, 08:53 AM
Mike
Here is another option that keeps things low to the ground.
This is an old picture and I do not have one with the cover removed. What you do is mount the motor end of the screw at the lower, forward end, of the number seven bulkhead, as low as it can go, right at the floor of the aircraft. You have to notch the upper floor to do this to allow for clearance for the motor. The lower corner of the number seven bulkhead is much sturdier then the upper attach location. The screw end attaches directly to the flap actuator with no modifications required. what you see in the picture is the cover that I made to cover the assembly. The top part of the cover is no higher then the seat cushion and will not affect any armrests that you chose to install. The cover is screwed to the floor, and removable, for inspection and maintenance. 1000 hours of trouble free use.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
