Go Back   VAF Forums > Model Specific > Rocket
Old 10-26-2017, 11:56 AM
Gt-401 Gt-401 is offline
Default Rocket lite performance
I'm not sure this will work, but this is a speed averaging app that i used to measure speed in the Rocket. I didn't write down OAT or density altitude, but the date mid summer, so i'm sure that it was higher than standard. I also didn't record the fuel burn, but I think it was up around 13 GPH.
https://www.runtastic.com/en/users/a...28a19624b42be1
Old 10-26-2017, 12:11 PM
Default normal cruise setting
Here is a recording of a more normal cruise power setting on the same day. I don't remember the exact fuel flow but it is normally below 9gph at these speeds slightly lean of peak.
https://www.runtastic.com/en/users/a...a7882e3e1f6fa0
Old 10-26-2017, 12:32 PM
Adrian Bonwitt Adrian Bonwitt is offline
Hi Greg, you have to be a "friend" to see the numbers in the App.
Any other way to get them to us?
Thanks!
Old 10-26-2017, 01:00 PM
Default try it now
I changed the privacy settings so that it should work now.
Old 10-26-2017, 03:40 PM
F1Boss's Avatar
F1Boss F1Boss is offline
Default results
~161kt to 178kt ground speed or so at 9GPH - close enough to call it 170kt TAS and about 155KIAS. Not too bad. Which model prop is on that ship now? I thought I heard Larry say he left the 540 prop on it...
Now we need average speeds from some of the 6cyl drivers...9GPH, and it looks like 3500MSL. What'll she do? No RPM mentioned, so just use some low-cruise MP and RPM.
Mine is an Evo, so that would not work as a point of reference. I do recall 7GPH/18"/1800 gives me an IAS of 140kt...OK in the summer when it's warm, but no can do in the winter: gets too cold.
Best,
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
Old 10-26-2017, 08:21 PM
Default More performance notes
I was at the hanger this afternoon and I grabbed my cruise notes, these are just hand written notes during cross country flights. The true airspeed are figured by the air data computer, but I have found it to be pretty accurate compared to the averaged speeds from the app.
Press alt. 11,500. Density alt. 13,360
GPH: 7.4
66% hp
MP 20.2. RPM. 2400
OAT. 42.2 f.
IAS: 150mph. TAS: 182 mph
This power setting was about 60 degrees lean of peak
Press alt 13,500. Density alt, 14,320
GPH: 7.4
64% power
MP: 18.6 RPM:2440
OAT:21 Deg F
IAS: 152mph TAS: 191 mph
This power setting was only about 20 deg lean of peak.
Press alt 9,500 Density alt, 10,900
GPH: 8
71% power
MP: 21.9 RPM:2370
OAT:45.1 Deg F
IAS: 163mph TAS: 194 mph
I'm not sure why it is calculating percent power so hi, but since all fuel flows are lean of peak, there should be a simple calculation to figure HP, but I don't know the factor for a 9.5: 1 compression ratio.
Old 10-26-2017, 08:27 PM
This Rocket has a Hartzell blended airfoil prop. I'm pretty sure it was new when he changed the engine.
Old 10-28-2017, 08:39 PM
Robertcropdust Robertcropdust is offline
Default Rocket/raider
I have a very nice complete HR2 0tt airframe that would make a great f4 conversion. Complete wings, empennage, fuselage, tinted canopy,cowling,wheel pants, wing tips,fiberglass fairings, new style hr2 engine mount and gear, Dynon autopilot servos installed, I have some extra parts that will go with it. This bird could be in the air fast. If anyone is interested please email me @ robertcropdust@hotmail.com
Harmon Rocket 2 sold
Built and flying Rv8 - sold.
Building F1 rocket
AT-402 office
AT-502 office
Old 10-28-2017, 10:00 PM
Originally Posted by Gt-401 View Post
....I'm not sure why it is calculating percent power so hi, but since all fuel flows are lean of peak, there should be a simple calculation to figure HP, but I don't know the factor for a 9.5: 1 compression ratio.
I use a very simple equation for any normally-aspirated engine:
% Power = (MP / 29.92) * (RPM / Max RPM).
It seems to get close enough, for me anyway, and is independent of compression ratio and leanness. This puts your final point at 64% power instead of the 71% power mentioned.
Old 10-29-2017, 09:37 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
AFR, exhaust back pressure (related to altitude), ignition timing and IAT also affect hp to a significant degree.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 424.4 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
