Old 10-19-2017, 09:16 PM
mfleming's Avatar
mfleming mfleming is offline
Default Completed Initial Leak Test of The Left Tank
Initial test of the left fuel tank has passed.
The Float access plate was tested with the cork gasket installed. Now that the initial test was a success, I'll pull the plate, remove the cork gasket, pro seal up the plate, reinstall and retest.
The multimeter is measuring ambient temperature for a reference as I recorded pressures during the test.
During the test I used a leak test fluid to check all the seams and rivets.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Empennage (sans fiberglass)
Ailerons and flaps complete.
Wings done (sans fiberglass)
Started on QB fuselage
Donated 2017
Old 10-19-2017, 09:22 PM
jcarne's Avatar
jcarne jcarne is online now
I'm keeping my fingers crossed for you. I'll be right behind you, I'll probably get to that in a couple of weeks.
Jereme Carne
PPL
RV-7A Emp. coming along
Working on Wings
Exempt but gladly paying!
Old 10-19-2017, 11:23 PM
Tag Tag is offline
Lots of luck! My RV8 tanks are being tested now also. So far, so good....
Old 10-19-2017, 11:32 PM
Beancounter Beancounter is offline
I will keep my fingers crossed for you too, that the cork gasket wont turn to goo like mine did.
C-GVMK
RV9a Slow(ly) built
Flying as of July 2012
Old 10-20-2017, 08:53 PM
mfleming's Avatar
Van's and Synergy recommend eliminating the cork gasket and just using sealer now.
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Donated 2017
Old 10-20-2017, 08:57 PM
mfleming's Avatar
Smile Second Tank Passed
Completed my initial leak check on my second tank today...Passed.
Tomorrow I'll seal up the end plates, let them cure for a couple of days and then do a final leak check on the tanks.
Using leak detection fluid to track down any leaks.
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Donated 2017
Old 10-21-2017, 08:03 AM
jcarne's Avatar
Great news!
Jereme Carne
PPL
Working on Wings
Old 10-23-2017, 12:21 PM
Draker Draker is offline
Did Van's post anything publicly to that effect? I'm getting close to closing my tanks up and am still going back and forth on "cork + Permatex" vs "cork + Proseal" vs. just Proseal.
Old 10-23-2017, 04:17 PM
RV74ME RV74ME is offline
When i took the factory tour, the guy there told me to toss the cork gasket as far as i could!!
Steve T.
N922WT (reserved)
KAUO (Auburn, AL)
RV-7 slow build
Tail kit COMPLETE
Wing kit COMPLETE
Fuselage kit IN PROGRESS
