Old 10-19-2017, 12:25 AM
Art_N412SB Art_N412SB is offline
UH1-H Driver. 162nd AHC Vultures and 18th CAC Green Delta. I was Green Delta one one. RVN 72
Old 10-19-2017, 12:27 AM
I forgot to mention that I was with those units at Can Tho as Well Ric.
Old 10-19-2017, 12:30 AM
sandpiper sandpiper is offline
Art - Rucker class 69-24. How about you?
John Horn (donated for 2018)
Independence, OR
LSRM-A, CFII
Rotax Service, Maintenance, and Heavy Maintenance Trained
Building an RV-12, N7878H reserved
Flying a Flight Design CTSW
Old 10-19-2017, 01:04 AM
crashley crashley is offline
Default idle speed
I would check the throttle levers are returning to their stops
also try removing the filters they may have too much oil changing the air flow
Old 10-19-2017, 04:52 AM
Fast Eddie B Fast Eddie B is offline
Originally Posted by crashley View Post
I would check the throttle cable is returning properly and has a little slack at idle setting.
At idle, the throttle cables are under tension, right?
I think I made the same mistake here and was corrected. My excuse was years with the same basic carbs on motorcycles where the throttle springs pull the lever to idle if a cable breaks. On the ROTAX itís the opposite - if a cable breaks the spring pulls it to full throttle.
2007 3i E-LSA Sky Arrow
CFI, CFII, CFIME
Old 10-19-2017, 06:35 AM
RV6_flyer's Avatar
How old is the 912?
Just had a 5-year old 912 on a E-LSA at my airport that had same or similar issue. (3,000 RPM idle)
Problem was gaskets in the carbs. One had the cork gasket around the outside of the float broken at the idle mixture jet and there were some O-Rings found were not correctly seated and one O-Ring was broken.
Replacement parts were better quality with a replacement cork gasket now a conventional gasket. Overhaul kit for both carbs was around $150.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 10-19-2017, 06:52 AM
John-G John-G is offline
Art ... you have received good suggestions so far. I would also like to add take a very close look at the throttle return springs attached to the throttle arm ... they have a propensity to break over time.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 10-19-2017, 09:16 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Art....my buddy (Joe Conley, who just bought half interest in my-12) and I both flew chinooks ( I, Innkeepers, he, Hillclimbers) for the first half of our tours; then ran the 307th TOC-Phantom, the second half. We were a little ahead of your time in Country.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 10-19-2017, 09:20 AM
jnmeade jnmeade is offline
It sounds like something common to both carbs. Throttle and cable, etc seem like something to double check.
Old 10-19-2017, 10:37 AM
71-27 at Rucker
