Old 10-19-2017, 12:55 PM
You've got it right. Just as an aside... When I did SB for my tank I elected to not install the new tank vent and instead to keep the vented cap. My reasoning is that I run 93E10 fuel and don't want a lot of air exchange in the tank which introduces moisture and reduces fuel octane. Best to keep tank sealed accept of small vent hole in the cap. 300TT and no problems with fuel flow.
I'm pretty sure I have mentioned this before......
The fuel tank vent system wasn't redesigned to solve a fuel flow issue (the original design did work just fine).
It was redesigned because a few owners overfilled their tanks with cold fuel, which then warmed and expanded, and leaked out the cap vent hole and ran down the side of the fuselage for an extended period of time which damaged the paint.
Scott McDaniels
Hubbard, Oregon
Old 10-19-2017, 01:59 PM
redbaron redbaron is offline
Smile New tank support and aft bulkhead
Check that the updated tank support and the split aft baggage bulkhead has been done. I must due items
Old 10-19-2017, 09:20 PM
Harvey rv12 Harvey rv12 is offline
I double checked the fittings on the bottom of the tank, I don't believe that is the source of the leak. I now understand that the return line runs all the way up into the filler neck. What is the logic behind that ?, to prevent bubbles from forming ?. I am not sure if I will put the extra tank vent in, have to think about that. What is wrong with drilling 2 vent holes in the fuel cap ?, for a little redundancy ?.
Tom O.
RV-12, bought flying
Hoskins Field, 44T
Olympia WA
the bitterness of poor quality
lingers long after the cheap
price is forgotten.
Old 10-19-2017, 09:23 PM
Iíve been flying mine since March 2012 and have about 650 Hours on it. I still use the vented cap exclusively. Simple works great!
Old 10-20-2017, 01:36 AM
Look here for easy method to find source of tank leak...http://www.vansairforce.com/communit...2&postcount=28 and http://www.vansairforce.com/communit...1&postcount=30.
The fuel return line ends in the filler neck so that head pressure is consistent. The flow is unimpeded by the level of fuel in the tank. Return fuel flow is always the same as seen on the EMS.
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 366
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 10-20-2017, 04:46 AM
Pat Stewart Pat Stewart is offline
Pat;
You mention removing the "vent line from bottom of tank first". The only vent I have is the fuel cap, and the only lines to the tank are the return line, and the fuel outlet to the pump, both on the bottom of the tank. Am I missing something ?.
I am going to install the newer design tank vent that I believe has vent line out the top of the tank and runs aft through the bulkhead.
Your correct, remove the return first.
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 10-20-2017, 06:30 AM
Default Why does return line run up into filler neck?
Ahh, constant head pressure. Why didn't I think of that.
Thanks to all for the guidance. These guys at Van's are pretty sharp!
Tom O.
Hoskins Field, 44T
Olympia WA
price is forgotten.
Old 10-20-2017, 06:49 AM
With the return line outlet being high in the tank, fuel can not siphon backwards. If a pilot elects to pull the red knob to shut off the fuel, he can be confident that fuel will stop flowing from both the supply and return lines.
An advantage to the fuel vent being located on the bottom of the fuselage is that if the airplane ever flips upside down, then fuel will not leak out of the vent.
Joe Gores
RV-12 Flying
Old 10-20-2017, 09:23 AM
This is the reason.
Since the RV-12 doesn't use a flow sensor for the return flow, positioning the return outlet so it is always above the fuel level makes the actual return flow constant which allows for a relatively accurate fuel flow calibration even without a second flow sensor.
Scott McDaniels
Hubbard, Oregon
Old 10-20-2017, 02:22 PM
This is the reason.
Do I win prize for having the right answer? Maybe RV-12iS?
Hinckley, Ohio
