Old 10-17-2017, 11:26 PM
simatos simatos is offline
Default Pipe thread on Andair filter-pump leak
Im using the Andair pump and Andair filter. They mate together with a pipe thread.
I have tightened it as much as I think is safe without damaging it but it continues to leak at this joint. Any idea how I might get it to seal.
Thank you
Gary
Old 10-18-2017, 12:04 AM
Pipe threads need a sealant. What are you using?
Do not use teflon tape. Do not use RTV.
Many like Permatex (#2, iirc), there are others.
Old 10-18-2017, 01:00 AM
Bevan Bevan is offline
I like Locktite 567 with PTFE in a tube. Amazon has it.
Bevan.
RV7A Flying!
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 10-18-2017, 06:48 AM
jcarne's Avatar
jcarne jcarne is online now
I have been researching this as well as I am working on the fuel tanks and need to seal some pipe threads as well. My research on the forums has revealed most use permatex #2 and Loctite 567. The loctite has had the most "rave" reviews.
Jereme Carne
PPL
RV-7A Emp. coming along
Working on Wings
Exempt but gladly paying!
Old 10-18-2017, 07:41 AM
permatex #2, PTFE sealant, Loctite 567, NOT teflon Tape. All of those have good results. YMMV. Used PTFE for years.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 10-18-2017, 08:27 AM
guys thanks
to the hangar now to give it a go.
cheers g
Old 10-18-2017, 02:54 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
You know, I have a question about this filter...I have the Andair pump/filter combo as well.
What's the point of the safety wire on the filter? If it's screwed into the pump at one end, and a fuel line (from the fuel selector valve, in my case) is screwed on the other, how would the filter case *ever* unscrew itself?
Granted, I don't have it handy, so I'm going by memory, but still...?
