Old 10-17-2017, 06:10 AM
Capt Capt is offline
Default RV7A man wheel track
Would someone be so kind as to let me know the main u/c wheel track width from outer spat to outer spat please?
Can't seem to find the info on the Vans site.
Thanks guys
Old 10-17-2017, 12:29 PM
Raymo's Avatar
Raymo Raymo is offline
Page 1A of the construction drawings shows 6' 8" from wheel center to center.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 10-18-2017, 04:16 PM
Thnxs for the reply, found an A model, 2.2M is about right, need to fit a rolling fuse into a truck🙂
Old 10-18-2017, 06:18 PM
Mark H Mark H is offline
When I moved my -7A I measured that I needed 91” clear open to fit the fuselage in a trailer. That’s a measurement outside to outside of the axle nuts.
Old 10-19-2017, 04:13 PM
Ok thanks for that measurement. That's about 2.3m, I have 2.36m to work with...phew!��
I have access to a 7 but wasn't sure if the A had the same wheel track.
Closed Thread
