Old 10-15-2017, 07:44 PM
E. D. Eliot E. D. Eliot is offline
Default Rotax push rods manditory check/fix
Received a note from Rotax that some engines that were built or rebuilt in 16' - 17' have bad push rods installed. If that issue was discussed here, I missed it - sorry.
I'm interested to know if anyone has info that includes the serial numbers of the affected engines. Thanks in advance for the info.
Building finally
Old 10-15-2017, 08:02 PM
KatanaPilot KatanaPilot is offline
I assume you want the SB for the UL engines. Hope this link works.
Krea Ellis
Locust Grove, GA and Miramar Beach, FL
DA20-A1 Katana "Princess Amelia"
RV-7A under construction
RV-10 under construction
Old 10-15-2017, 10:52 PM
Default Thank you Krea
Thank you very much - I appreciate. Very helpful and timely.
Building finally
Old 10-18-2017, 10:34 AM
waterboy2110 waterboy2110 is offline
Yes I have one of the affected engines. Haven't even had a chance to start it yet and got a call letting me know we need to take it apart.
Beyond disappointed with Rotax, their US support and the lack of quality control in manufacturing.
I did start a thread with the SB number but it was fairly cryptic in the subject.
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P / Rotax iRMT 9 Series Maintenance
RV12 Flying.
Old 10-18-2017, 07:51 PM
bpattonsoa bpattonsoa is offline
I have a brand new Rotax still in its shipping box for my Rans. It was on the list.
Took about 30 minutes to remove the valve covers and check all the pushrods with a mirror and flashlight (because it was in the box) and button it back up. Didn't have to rotate the crank, there is enough of the pushrods showing to see the color of the tips. If the engine is mounted it will be easier.
All was good. The inspection is easy, if you have a wrong pushrods it is a different story.
Bruce Patton
Building Rans S-20 Raven 796S reserved
Going to the light side!
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S tail, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum, interior complete. 1624 lbs, FLYING after a 21.5 month build.
Old 10-19-2017, 09:04 AM
Thanks - I had intended to have a look but put it off because I'll be purging the oil system in a couple days and will pull the covers then. Perhaps I'll have a look today.
PP - ASEL
Instrument Rating
RV12 Flying.
