Old 10-15-2017, 04:21 PM
DeltaVee47 DeltaVee47 is offline
Default Sequence
Evening all
I am at section 30, joining forward fuse to aft and wondered if it would be ok and easier to complete sections 31,33,34 while the forward fuse is on the floor rather than up on horses. These are sections on fuel lines, brake lines etc. that have nothing to do with baggage compartment etc. Iím sure this been answered before but I could not find with the search function.
Thanks for your thoughts
Greg Beckner
140366
Old 10-15-2017, 04:38 PM
bkervaski's Avatar
bkervaski bkervaski is online now
I can't think of any problems with that strategy.
Progress: Away for PAINT
Old 10-15-2017, 05:29 PM
Don E Don E is offline
Default Thatís what I did
While awaiting space in my shared building to join the fuselage sections, that is what I did. Also seat backs. Have not experienced any downside to that so far.
Old 10-15-2017, 05:42 PM
mturnerb mturnerb is offline
Precisely what I did except for section 34 (flap actuation) - you really need to wait on that one until after the baggage floors are in, because the structure it attaches to is part of the baggage floor section, which has to be done AFTER the fuse/tail join. I'm completing 35 also before I join fuse and tail. This is equivalent to building the QB fuse, plus brake and fuel systems. I'll finish the rudder install after the join (running cables to pedals etc)
I ran this plan by my EAA tech counselor (Vic Syracuse) who saw no issue with it.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 10-15-2017, 07:36 PM
Default Flaps...
Most of the flaps actuation - everything except the connection to the flap motor shaft - can be done in advance.
Old 10-16-2017, 05:07 AM
I guess I didn't study the baggage floor section/ flap actuation sections well enough. I'll look again, because I want as much done as I can before the "big join"....
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 10-16-2017, 05:18 AM
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 10-16-2017, 05:53 AM
Default Rudder cable
One caution - it's fine to build the brake pedals and install the rudder/brake assembly, brake lines, etc. However, do not run the rudder cable into that section if it is already in the tailcone, as it has to go through a hole in the leading edge of the baggage area floor. And it would be a right bugger to take it back out to route it thru there.
Old 10-16-2017, 07:26 PM
Excellent. Good catch.
Greg
N557GB reserved
