Old 11-11-2017, 05:11 PM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Resolved?
John,
Did you find the issue?
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 175+
2018 Dues Paid
Old 11-11-2017, 05:28 PM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Kind of resolved....
I did not find an issue as far as something I could fix.
No leaking in the fuel system. Put a wrench on all the fittings and gave them a little snug.
My new OP is to hit "Both Pumps" when switching tanks.
Hasn't happened since July.
Of course it hasn't been as hot.
I really think it has something to do with the heat. I'm certainly not able to duplicate it.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
Old 11-11-2017, 05:40 PM
M McGraw's Avatar
Default Fuel pressure
I agree, that is a lot of engine, extra fuel won't hurt in high temps. Keep us up to date. Are your fuel pumps on the cold side of the firewall?
Marvin McGraw, 5TN4
Flight hours: 175+
2018 Dues Paid
Old 11-11-2017, 05:45 PM
Bluelabel's Avatar
They are... even thought the tunnel in the 10 notoriously has heat issues.
I do have gold heat reflective panels on the belly right above the exhaust (which did make significant difference the the temp of the floors when flying). Plus I have the tunnel well insulated as well as the firewall.... so, I've done what I can to control those temps.
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Lead on the
twin turbo, IO-540,
2017 Dues Paid"
Old 11-11-2017, 06:19 PM
9GT's Avatar
9GT 9GT is offline
In addition to insulating the tunnel, I fire-sleeved all the aluminum fuel lines in there and had a split fire sleeve that fit around my Andair fuel pump, with the the filter and Red Cube transducer. Never a hiccup switching tanks, even without the boost pump ON running mogas. I used the red silicone Stratoflex stuff.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2018
Old 11-11-2017, 09:43 PM
Bevan Bevan is offline
I'm thinking vapour lock. Where in the system is your fuel flow transducer?
Bevan.
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 11-12-2017, 01:39 AM
scsmith scsmith is offline
My vote would still be that air is getting into the unused line at the fuel selector valve. Depends a lot on the design of the valve, and I am not familiar with the Andair, so I can't help with details.
But I think a lack of fuel in the line you are switching to is the only hypothesis that fits the observations.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 515 in 9 years (would have flown more this year if not for fire smoke)
also LS-6-15/18 sailplane
VAF donation Dec 2017
Old 11-12-2017, 06:33 AM
M McGraw's Avatar
Default Cones
John,
Have you tried conical seals on the valve line fittings? This would address the possibility of air in the lines.
Marvin McGraw, 5TN4
Flight hours: 175+
2018 Dues Paid
Old 11-12-2017, 09:16 AM
Bluelabel's Avatar
Bevan.
Well, the good thing about the EFII system is I donít need one of those. The system sends a fuel flow signal to my Garmin. Once you get the Kfactor number dialed in, itís super accurate.
Originally Posted by M McGraw View Post
John,
I have not, I didnít even know that existed, but Iíll do some research on them. THX
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Lead on the
twin turbo, IO-540,
2017 Dues Paid"
Old 11-12-2017, 09:45 AM
PFEIFFO PFEIFFO is offline
Default Switching fuel tanks.
Never ever experienced that ( 270 hrs on RV10), Have fuel injection and never turn on fuel pump while switching tanks in either my RV 8 or RV10. Is all your system in the tunnel or part on top the engine? D Pfeiffer
