Old 05-06-2017, 02:39 PM
Sam Buchanan's Avatar
been here awhile
Originally Posted by Toobuilder View Post
To those who are going to use regular channel lock pliers on them, use caution: they store a lot of energy and slip out of the jaws easily.
These pliers will prevent a lot of creative vocabulary (and possibly personal injury) when using spring clamps:
http://www.aircraftspruce.com/catalo...ickkey=3008670
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 05-15-2017, 05:08 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Help with purchase
This sounds great, would like to do this on 3 engines.
Would someone help with info?
Intake tubes from Summit....good link!
Roto clamps= HC-34 PDF said lot of 500 but Toolbuilder got 100 and was selling some.
Oil return lines..McMaster-Carr ? P/N ??
Would be good to have all the info in one place.
Thanks for all this help....wonderful idea.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 05-15-2017, 05:56 AM
madhun madhun is offline
Nice idea. Used regularly on really cranky tuned turbo inlets and compressor outlets sitting atop glowing red exhaust manifolds. Should handle the job satisfactorily.
Quentin Carter
Bushby Mustang II - 170hrs and counting
$500, if Mrs. Hun ever asks aircraft parts are $500!
Old 05-15-2017, 07:19 AM
Toobuilder's Avatar
I got my bag of clamps from MSC Direct.
https://www.mscdirect.com/product/de...rItem=48690382
I dont know the proper PN for the oil return line clamps, but they are also manufactured by RotoClip and should be available from MSC.
Michael Robinson
______________
RV-8 - Flying
Old 05-15-2017, 02:01 PM
Bob Martin's Avatar
Default oil return line clamps
Thanks Michael,
Good info.
Anybody know the P/N of the oil return line clamps? Assuming the standard hose.....
Bob Martin
Old 05-15-2017, 03:16 PM
Euro & Asian car makers use flat wound versions of those clamps. Much better for silicone (more surface area), but harder to find.
Old 05-15-2017, 06:39 PM
Toobuilder's Avatar
Actually, the new American OEMs use the flat style too, and Roto Clip is the likely supplier since the flat style is also in their catalog. I switched to the wire type after reading the product specs for both. The higher specific clamping pressure of the wire is what I'm looking for in this application. Since neither the tubes or sump have a retention bead, I'm looking for a high 360 degree point seal.
Michael Robinson
______________
RV-8 - Flying
Old 05-18-2017, 08:49 PM
160kt 160kt is offline
McMaster sells quantity of 10 clamps for $5.73
https://www.mcmaster.com/#5324K55
Old 06-28-2017, 03:55 PM
LordofWar LordofWar is offline
Post Feedback
My Oil return lines are leaking and looks like I have the same issues as everyone else.
Whats the feedback on the Constant-Tension Spring Clamps from someone who used them? I'm planning to get them from McMaster Carr https://www.mcmaster.com/#5324k55/=189qeo8
Planning to get the below sizes for O-320(correct me if I'm wrong)
2 1/8" Clamp - for Intake Hose
5/8" Clamp - for oil return hose
Your input is much appreciated.
Rajiv Chalasani
RV-6 - Red Phoenix (N111BN)
RV-10 - Tail Kit Started
2017 Dues Paid
Old 06-28-2017, 08:46 PM
bruceh's Avatar
bruceh bruceh is offline
I did this on the oil return lines and it has been leak free for the last 2 years.
I don't recall the size of the constant tension clamps. I got a foot of oil hose from the local auto parts store and cut it into 4 pieces.
Bruce Hill
RV-9A N5771H flown over 500 hours!
2018 VAF donator
EAA Tech Counselor
