Old 04-13-2014, 08:35 PM
jwilbur jwilbur is offline
Default Front Floor Side Alignment
This seems a little weird. When match drilling, all was good and right. But now that I am installing the front floors, the outboard-most hole alignment is off (These are the holes on top of the joggle that attach to the channel which is in turn attached to the skin). The miss-alignment is off the same amount on both sides of the airplane. I can flex the skin/channel enough to get clecos in, but it seems to take a lot of force. Has anyone else encountered this?
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
Pink slip - 7/2017
RV-10 Build Log
Old 04-13-2014, 09:13 PM
daviid daviid is offline
while im not even close to this part. is it possible you put the left on the right and vice versa?
David King
RV-10 #41517
N484DK (Reserved)
http://rv10.daviid.net
Old 04-13-2014, 09:24 PM
digidocs's Avatar
digidocs digidocs is offline
My floors required quite a bit of force in that area, too. I'd cleco it up, take a look at the outside contour, and if good install those rivets!
David
The shape of the floor panel makes that impossible.
Phase II - 11/2017
Pink slip - 7/2017
RV-10 Build Log
Old 04-13-2014, 09:31 PM
Default oil can
David
Thanks David. I'm glad to hear this. The contour does look OK after I get the clecos in place, but then I noticed a bit of oil-canning. Temporarily installing the forward fuselage rib (with clecos) does help with the oil-canning, but it's most definitely still there. Any oil-canning with you?
Phase II - 11/2017
Pink slip - 7/2017
RV-10 Build Log
Old 04-13-2014, 09:41 PM
digidocs's Avatar
Hi Joe,
I don't have any noticeable oil canning in that area, but I didn't check for that before installing the ribs. I'd like to believe that riveting in your ribs (vs. just clecos) will stabilize everything nicely.
David
Old 04-14-2014, 03:36 AM
rleffler's Avatar
rleffler rleffler is online now
Hi Joe,
David
It's been too long since input those parts,together that I don't remember all the details. I do recall using a 4ft pipe clamp to pull things into alignment. What I can't recall if it was the floor or the outside skin that was my problem.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 04-14-2014, 06:37 AM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Default I too had that problem
I also remember having that problem. Maybe not quite as bad as yours but I do remember pushing on the side to get the clecos in.
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 04-14-2014, 08:19 AM
Any oil-canning? Google tells me that others have had oil-canning in this area in the past. I wonder if this is why. What Google doesn't seem to know for sure is if those who have had oil-canning at this stage see it disappear as the build progresses. There were some suggestions that it would (or might) when top skin is in place and when engine is installed. I'm trying to figure out if I should install an additional stiffener. It'll be pretty easy to do now - not sure how easy later.
Phase II - 11/2017
Pink slip - 7/2017
RV-10 Build Log
Old 04-14-2014, 09:54 AM
Default None
Don't have any oil canning (At least in the fuselage). I do have stick-on sound insulation in that area as well. (In case it has an effect)
Bill Thomasson
Suwanee, GA.
