Old 11-08-2017, 09:14 PM
rocketman1988 rocketman1988 is offline
Default Hmmm...
So you wrapped a brass bushing with aluminum tape and put it inside a steel weldment? Isn't the point of the brass bushing to give a greater bearing surface as the control stick base pivot tube rotates around it as depicted in section 39-8?
It would seem that wrapping that bushing with a MUCH softer metal for a steel tube to rotate and bear on would be problematic...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Dues Paid 2017,...Thanks DR+
Old 11-08-2017, 10:02 PM
9GT's Avatar
9GT 9GT is offline
It will probably eventually wear,,,,,,,sometime in my lifetime. Then it just gets sloppy again. The welding process will distort the inside of the tube the bushing fits in. The best solution is for the stick fabricators to ream the inside of the tube back to size after welding fabrication, and for Vans to provide correct diameter bushings for the reamed holes. I have found that most of the Van's fabricated parts receive little clean-up. Now that I have a metal lathe, I would ream the inside of the tube and turn a custom bushing.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2018
Old 11-09-2017, 04:06 PM
Wyzepilot Wyzepilot is offline
Originally Posted by Wyzepilot View Post
Im wondering if maybe Vans fixed this issue because I just completed this step last week and the bushing fit quite snug in the base. In fact I had to convince it to go in that last little bit with a plastic tip hammer.
Dave
Disregard my last post. I just checked today and I also have about 1/8 of play.
Old 11-09-2017, 04:58 PM
See... http://www.vansairforce.com/communit...&postcount=288
Hinckley, Ohio
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 391
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
