Originally Posted by jnmeade
It sounds like something common to both carbs. Throttle and cable, etc seem like something to double check.
No, can quite easily be just one carb. Take a look at both EGT's and see if they are close to same temp. If not, higher temp EGT is imbalanced carb and doing most of the "work".
