dan carley
i'm having problems in climb, at 120mph i only get about 1500 fpm and the climb will not hold i have to keep pulling back to hold 1500. in cruise is fine 2450 about 170 moh, top speed 2800 205 mph. i've changed props with no luck. checked mag timing ok, i do have electronic ing, could that be where the problem is? i have no way of checking the electronic ing.
static run up 2090 rpm's. climb out 2200 rpms
i'm really stuck on this one???
dan carley
dan carley
