Rotax 912 iS Sport instead of the 912 ULS?
epaslick
Active Member
Patron
I have a question you RV-12 E-AB builders. Has anyone considered installing the Rotax 912 iS Sport instead of the 912 ULS? How much would have to be changed to make the iS Sport fit and how much added difficulty would that cause?
Yes! If you are a first time builder it would be very difficult.:cool:
Fuel system would be different.
Weight & balanced would be different.
Empty weight would be higher.
Cost of engine about $4000 more.
Cowl would be different.
Electronics would be different.
Increase build time by about 500 hours.
Etc, etc.:p
I would also think there may be some wiring and configurations in the Skyview that would need to be taken care of. From what I recall from about reading - the IS has some upgrades available just to get it to the power of the ULS so what's the point unless you just can't stand the idea of a carb(s). I think the turbo Rotax is about 30lb heavier.
From my morning read in KitPlane changing out engines on a designed platform is not for the faint of heart. The article stated that insurance would be an issue and that the fly off would increase (the article eluded to a 25 hour eab if not to many deviations to a 40 if you change the PP - I've read about the FAA being liberal with fly off periods but have no experience with it... yet).
My apologies, I didn't phrase my question very well, my fault. I was wondering if anyone else had looked into it and had specific details about what had to be changed and what could be kept from Van's... :eek:
Etc, etc.:p
Any more difficult then building a 7 or 8 or 9 and choosing a non-Van's engine?
Different lines firewall forward for the fuel injection I would expect, but would you need to change anything aft of the firewall? What about fuel pumps?
If the info on the Rotax website is accurate and I did my mental math correctly, the iS Sport would add about 15 lbs.
See above.
Van's powerplant kit for the RV-12 is currently $28,738.00 plus s/h. I don't know what they include in the kit though, as I haven't seen a breakdown. So I don't know the cost of any of the extras I'd need. I've seen adverts for the barebones ULS as low as $16,000.00, and as high as $22,000.00. The only price I've seen for the iS Sport so far is $23,918.00.
Yes, I would expect to have to mod the cowls. I would also expect the baffles to be different as well.
I would expect additional wiring for the engine management system.
I've read on the forums that there are RV-12s with Vikings and Jabirus. I'm guessing that's the amount of additional time it took those builders to mod their RVs... :confused:
So I would expect.
That is not my understanding. The difference is both the fuel injection and the engine management system to increase fuel economy. I haven't seen anything that says they had to mod the engine to increase hp.
And it's not so much that I don't like carbs, but I really don't like dual carb setups. I've had bikes with both 2 and 4 carb systems and they have never been anything but trouble for me.
The iS Sport is not a turbo engine. It is approximately 15 lbs heavier than the ULS.
I believe 40 is the most common E-AB phase 1 time. :)
I too have been wondering about the 912IS Sport. I think I read somewhere that Cato was developing a prop (the one's I've seen are works of art) that would offset some of that weight difference.
The additional fuel savings would sure stretch that 20 gallon tank!
Bob
FAA rules state that the minimum phase I flight test period is 40 hrs. for a non-certificated engine/propeller combination installed on an Experimental Amateur-Built aircraft. If anyone give less, they are violating the rules.
Ah - my comment about the upgrade was to get the IS to the sport version. New mapping and air box I believe. Sorry about that.
Mel - I'm pretty sure the USL is not a certificated engine. My understanding is that's quite a bit more money. What gives? For ELSA is the rule ignored?
The 912 ULS is not a certificated engine. Phase I test period should be a minimum of 40 hrs. for EAB.
For ELSA the rule is different. Phase I flight test for ELSA is 5 hrs. min.
Nice movie from Rotax-Owner about installation of a 912IS in a CH750 and with that the redesign of the fuel system -> YouTube
I haven't had a chance to watch it all the way through yet, but it does look very interesting. 2 fuel pumps firewall forward... and I noticed they did not have any baffles installed... :confused:
While the design is quite complex, the engine is amazing; the redundancy, ease of operation (including telling you how far to move the throttle to start based upon engine/environmental parameters), etc.
Wow!
Bob
One fellow on our field has a Pipestrel Virus with an early 912IS installation that had a number of engine issues. I was told that, to diagnose the problems, they needed a specialized Rotax tool plugged into the system - and it was expensive.
You might want to investigate how diagnosis and service of problems on the 912is compares to the bing-carb models before you commit. Parts cost for those pricy items might be a factor too.
Eric - the Rotax 912 has the equivalent of "baffles." Underneath all that wiring and hoses on top of the engine is a fiberglass shroud that covers the fins on the shanks of the cylinders. That shroud has an inlet to which you connect a scat tube with air from a cowl opening. Air blows across the fins and down. ROTAX can supply their shroud or people make their own - Vans RV12 does not use the Rotax one but one from Vans.
The cylinder HEADS are liquid cooled.
Viking fuel injected+whilrwind 3 blade prop
I am installing a Viking fuel injected engine (Honda) vikingaircraftengines.com with their cowling and a Whirlwind 3 blade prop. At 1/2 the cost of a Rotex and they have a firewall forward kit and dual fuel pumps. Check out the install info at Viking site.
