Hello ladies and gentlemen.
I am slowly starting to work on fairings. elevator / HS is fine as far as fit goes.
On the rudder / VS not so much...
Here is what I got:
If I try to close the edge #1 then edge #2 is not going to be in line with the LE of the VS. I cant move the whole thing up because then I wont have enough material on the bottom for the rivets with ED...
What is the route you guys have used or would use?
Thanks for all the help.
Here is what I got:
