Old 09-02-2018, 02:56 PM
charosenz's Avatar
charosenz charosenz is offline
Originally Posted by ccsmith51 View Post
I can see all pics fine. Nice work!
Thanks. It is a lot of work but a lot of fun too.
Charlie
Old 09-09-2018, 08:36 PM
charosenz's Avatar
Default Intercooler tested
Update:
For those that may occassionally want an update. I tested the intercooler installation this weekend.
I was very impressed with how effective it was. even though it was a $90 ebay intercooler, I found it was very well made.
I did a run up to 5200 rpm only about 38-40 " MAP. The ambient temp was about 80 f and max temp temp as about 82*-84* IAT. Test before the intercooler I would see my IAT head over 150*.....
I then activated my #2 meth injector and it dropped down to 68*-69* . This is a very small injector and if I wanted it to drop further I would double it to a #4. some go as hight as #10. These numbers generally equate to gallons per hour and you can get them from McMaster Carr for only a few bucks a piece. They come with built in fine mesh screen. Excellent in expensive nozzles....
So for me, if you are running a turbo, you really do benefit with an intercooler - IF - you have room and can afford the extra weight.
If you don't have room for an intercooler I would definitely use meth injection.
Here is a link of a short video of the engine running on a test stand up to 3000rpm.
https://youtu.be/752RATYxUBk
There is a lot to share on Wide Band AFR systems but that will be on another post later.
I would appreciate if at least one person can tell me the video link above worked for you.
Feel free to ask questions.
Old 09-09-2018, 08:44 PM
DHeal DHeal is offline
Your video links looks great!
EAA #23982 - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 670+ hours (as of Sept 2018)!
VAF donation through June 2019.
Old 09-09-2018, 09:03 PM
charosenz's Avatar
Thanks, glad you liked it and good to know it works.
Charlie
