New Cold Air Intake
tgibbs
Active Member
I'm on the hunt for a new oil sump for my Lancair as the one I have is warped from welding and leaks (longer story). It looks like Superior and Sky Dynamics are the two out there with a considerable difference in cost between the two. Sounds like quite a few guys have the Superior one. Anybody have the Sky Dynamics one? Fit good? Are there fundamentally any differences between the two?
I emailed Sky Dynamics basically asking why I should buy theirs over the others and spend the extra money but no reply as of yet.
Hi Lance,
I’m exploring options for an IO390 for my RV14. Thought I’d touch base to see what you ended up going with?
Hi Lance,
Blast from the past but I ended up going with the Superior one. I ended up putting it on my RV4. The Sky Dynamics one was a year lead time at the time. The Superior product is pretty decent.
I have a Sky Dynamics sump & intake. Very well made but very long delivery time - nearly 2 years from order. The SD set up moves the injector forwards by nearly an inch which may cause some problems. I am very happy with the result, definite weight saving and performance bump over the regular Lycoming horizontal sump/intake. If I did it again I might go with the Superior product just because it is more readily available.
