GAMI Info
I saw that the GAMI folks were working on an electronic ignition. If their efforts are up to their usual standards it may be worth waiting for. Here is some of the email excnange I had with them. George
----- Original Message -----
To: George V. Goff
Sent: Thursday, December 02, 2004 9:27 AM
Subject: RE: GAMI's PRISMT Electronic Ignition -
George,
It is not yet available for experimentals.
It will handle any and all engines provided that the timing unit physically fits on the engine and the timing gear ratios are correct for that engine.
So having said that, almost all common, horizontally opposed, TCM and Lycoming engines in use today in GA aircraft (and some swamp boats) will be able to use our electronic ignition system.
John-Paul Townsend
-----Original Message-----
[email protected]]
Sent: Wednesday, December 01, 2004 9:26 PM
To: comments
Subject: GAMI's PRISMT Electronic Ignition -
Is your GAMI's PRISM? Electronic Ignition - available yet for experimental aircraft?
When it is available will it handle non-fuel injected engines?
Is it aimed at the top end market (in HP) or will it handle an O-320 with high compression cylinders (160 HP)?
Thank you, George Goff
