Old 07-06-2011, 06:03 PM
jbagley's Avatar
jbagley jbagley is offline
Default Garmin SL30 alternatives?
Looking to replace one of my two Icom A200's with a nav/com sometime in the next 6 months. The Garmin SL30 is obviously the industry standard in that size, but what other options are there? Any?
New SL30's are about $3700 and used ones seem to sell for ~$3000; so it doesn't make any sense at all to buy a used unit. I'm just wondering if there are any other cheaper or better units out there that I should be looking at?
Thanks!
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
Old 07-07-2011, 09:43 AM
N941WR's Avatar
N941WR N941WR is offline
Why not install a 430w and sell one A200?
That way you get even more capability in you panel.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-07-2011, 09:48 AM
jthocker's Avatar
jthocker jthocker is offline
Super Moderator
Lets see, $3700 for the SL 30 and $7500 for a 430, that wasn't much help for a cheaper option was it!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Redline Air Shows
http://www.redlineairshows.com
Upgrade your RV from "Steam" to "Glass"
http://www.redlinethegoal.com
Old 07-07-2011, 09:59 AM
AltonD's Avatar
AltonD AltonD is offline
No, but if I were to do it again, I would save my pennies and install a second 430W. I currently have a 430W and a SL30.
My setup works great, I just see added benefits in two 430Ws for IFR.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~800 hours since Aug 2010
N4IDH
Construction Log
“The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.”
Mark Twain
Old 07-07-2011, 10:06 AM
jbagley's Avatar
Default 430w
The 430W is a great unit! Some of the rentals I did primary flight training in had them. It's just a bit outside my budget, both initially and continually (database and software updates).
Primarily, I want a nav/com to do IFR training in my rv6a. I couldn't find any nav/com, other than the garmin sl30, in the same form factor as my existing Icom A200.
James Bagley Jr
RV6A flying
Old 07-07-2011, 11:54 AM
ksauce ksauce is offline
Default Mgl
Mgl has been threatening to release a nav radio for quite a while that should be comparable to an sl30. Knowing mgl, it will be a good price. With any luck, we might see it at oshkosh.
Kevin
Old 07-07-2011, 01:10 PM
jbagley's Avatar
Default MGL
Sounds like the MGL nav radio will be a nav-only remote radio. From the vague description on the website, that sounds like it will plug into your MGL EFIS and be controlled/operated solely by the EFIS. That's not necessarily a bad thing and would be worth waiting for *if* it would work with the Mini-Extreme and be priced under $1k.
Then I could get an EFIS, nav radio and CDI for less than the cost of the Garmin SL30 alone. That would be pretty nice.
James Bagley Jr
RV6A flying
Old 07-07-2011, 01:22 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default MGL Radio...
I think it is already available:
www.mglavionics.com/html/radios.html
This web site is the MGL site from SportFlyingShop.com. I purchased my MGL instruments from them for my last Experimental, and cannot recommend SportFlyingShop.com enough. Matt is the best at support.
Chris Smith
Maule M5-180C
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Orlando, FL
Old 07-07-2011, 01:25 PM
John Courte John Courte is offline
The V10 comm doesn't have the NAV functionality of the SL30, but it does use the SL30 remote protocol for frequency setting.
The V15 (I think) NAV radio was supposed to do the other half, but it's not available yet. Not sure where they are on this one. I was going to put a V10 in my -7, but I wound up getting a 430w instead.
Phase II as of 7/19/2014
http://stjohn.openbar.com/airplane
Old 07-07-2011, 03:08 PM
jthocker's Avatar
Super Moderator
Well, instead of offering James an opinion on what one might think is best for him, and his BUDGET, I'll try to be helpful.
http://www.sarasotaavionics.com/usedavionics.aspx
A link to Sarasota used avionics
KX 125 used Nav/com $1889
Jon Thocker
Habitual Offender
Redline Air Shows
