Old 02-17-2015, 08:58 AM
jchang10 jchang10 is offline
Default Easy way to cant the copilot screen
Hi all, i recently added a second EFIS screen in front of the copilot. I just mounted it straight hoping for the best. However, I think it needs a cant to the pilot view. I was hoping to get some opinions on possible best and easiest method to doing this. BTW, this is a 2nd Skyview screen.
I could cut some Al tubing or even bend some metal on a brake. I was just hoping to hear from someone who has already done this and maybe what they did.
Thanks!
Jae
#40533 RV-10
1/2006 Started build
10/19/2011 First flight
11/26/2011 Phase 1 Done
12/25/2013 First coast to coaster HAF to K88 to JYO
Old 02-18-2015, 01:54 PM
Bump. Someone must have done this.
#40533 RV-10
Old 02-18-2015, 01:56 PM
Paul Dye did a canted screen on his RV 8-------you might be able to search for it, I know there was a thread with photos and a nice writeup.
Old 02-18-2015, 02:53 PM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
Mine is going to be canted also but not designed yet.
So, in the meantime,:
http://www.vansairforce.com/communit...ghlight=canted
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 02-18-2015, 04:59 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Basically, make two triangular-shaped wedges, with flanges all around, Pick up the existing screw holes/nut plates in the old cut-out with one set of holes in the flanges, and attach new nutplates in the other flange to receive the screws for the unit. The great thing about this system is that if you don't like it - you remove it, and haven't lost anything!
I stole the idea from Smoky (I think)....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-18-2015, 05:05 PM
Awesome. Thanks for the update. I see that you used .040 whereas the panel material is .060. I am glad to see the 040 worked out well.
It's funny, just seeing it done and the positive comments around it, is enough motivation to get my butt moving on this!
thanks for the update!
Jae
#40533 RV-10
Old 02-18-2015, 05:23 PM
SteinAir SteinAir is offline
Hi Jae,
We've done many such variations of these over the years, and depending on what/where the screen is, you can do a number of different things. In the pictures below, we simply did what Paul said...made a metal wedge!
I'll see if I can dig up some other various and sundry examples.
Stein
Old 02-19-2015, 07:38 AM
Snowflake's Avatar
Looking at that last photo makes me wonder... Why not cant the pilot's side screen towards the passenger, too? It probably wouldn't make a significant difference to the person sitting in front of it, but it would be nice for the passenger (or second pilot?) to see across?
I guess the lack of symmetry offends my industrial design experience... :P
Rob Prior
Old 02-19-2015, 09:48 AM
Thanks Stein. Those look good as well.
After just a few short hours with the dual screen setup, i think having a canted screen is necessary if you want to utilize the copilot screen from the pilot's seat. Some day, i should video myself leaning way over to the copilots side trying to figure out what i am seeing.
As far as the asymmetric design, it was good enough for Cirrus. Also, i know of a former Cirrus owner and now a builder who built a incredible Lancair ES, who wanted to duplicate the cockpit and panel of the Cirrus. I found an article below. I count 5 Al surfaces out of a single piece of Al that he had bent that happen to intersect a point about a couple inches round, conveniently near his eyeballs. That took some extra doing.
http://verticalpower.com/_documents/_pdf/kp.08.13.pdf
#40533 RV-10
Old 02-19-2015, 02:56 PM
GrayHawk's Avatar
I'd like to design an adjustable one (canted or not canted), usable on both side, pilot, passenger or co-pilot; and then some people like to fly from the tight seat.
GH
GrayHawk
