Old 12-24-2014, 05:07 PM
Christopher Murphy Christopher Murphy is offline
Default Carb ma4spa
Frustrated!
I took my carb that, was running just fine, off to install the metal float kit. Put it back together using the 7/32 float dimension. Put it back on, it started and ran but was too rich. I took it off and lowered the float level using 9/32 dimension. Put it on and it leaked fuel from the vent on the bottom. Took it to the shop where a fuel tech reset the float to 7/32 tested the needle and seat( good) and tested it on the flow bench. All checks good. I put it back on the engine and it leaks even worse now. The float is not sinking.
Any ideas?
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
Old 12-24-2014, 07:17 PM
Sid Lambert Sid Lambert is offline
You may have a tiny bit of trash under the needle. It happens.
Take it out and examine the needle & seat.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 12-24-2014, 07:45 PM
Default float kit
I installed the kit that the kelly aerospace rep at oshkosh told me was the correct one. He gave me the part number.
Ive had it open 3 times...condition and trash in the needle seat were checked by me and the fuel tech..as well as integrity of the float.
Its got me baffled?
RV-4 "Mr. Twister"
Old 12-24-2014, 07:49 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Put it back as it was...
Reiley
N622DR - Serial #V7A1467 RIP Aircraft Drowned in the 05/2015 Memorial Day Flood
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 12-24-2014, 08:07 PM
Default im tempted to
I am tempted to put the white float back in...
i hate fixing things that arent broken..
RV-4 "Mr. Twister"
Old 12-24-2014, 09:54 PM
Yes Sir... if its not broke, don't try to fix it.
Reiley
VAF# 671
Friend of the RV-1
Old 12-25-2014, 01:55 AM
PCHunt PCHunt is offline
IIRC, the metal floats are not the latest version. The newest ones are blue epoxy. I just installed a float kit in my MA4-SPA carb with no issues. Removed the older but functional metal (brass) floats.
YMMV
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2017 Donation+ Sent
Old 12-25-2014, 07:00 AM
Walt's Avatar
Walt Walt is offline
Definately DO NOT put the white plastic float back in, those are the ones that caused all the problems.
What is your fuel pressure running? (4-6 psi is normal)
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 12-25-2014, 07:15 AM
Default metal float
The kelly aerospace guys said to go with the metal float. we had a long discussion about which float should be in the carb
we tested the needle and seat at 6 psi on a flow bench... it was fine.
put on the airplane and it pisses fuel out. 4psi max on the plane
it shouldnt be rocket science..lol
I will eventually figure it out but I was wondering if there was something else
that might cause that isse
merry christmas
cm
RV-4 "Mr. Twister"
Old 12-25-2014, 07:29 AM
Walt's Avatar
My carb shop would agree, the brass float is fine and they will re-use those but the white ones get replaced with the new ones because the brass is no longer available.
You may just take the carb off and hold it level to see if the same thing still happens, perhaps the steep angle is causing the issue somehow. I would also double check the FP with a seperate gauge just to be sure.
