Old 11-22-2013, 09:13 AM
mtnflyer mtnflyer is offline
Default Mag cap
I'm helping a friend on his airplane and we have problem. There is very clearance between to mag cap and the firewall, not enough room for the wires. Has anyone out there heard of a mag with the wires coming sideways??? Thanks
Old 11-22-2013, 10:12 AM
Ironflight's Avatar
VAF Moderator / Line Boy
What airplane? The tightest RV I know is the -3, and Slicks will just fit (very much like a Yankee). If you are open to different ignitions, the P-Mag wires seem to give more clearance.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-22-2013, 12:41 PM
deek deek is offline
The ACS harness can be bent into shape a little easier than the Slick. EZ's have this problem too, especially on the impulse mag.
'83 LongEZ - N888EZ 3,314 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 11-23-2013, 05:21 AM
Sad to say, this not an RV I'm working on, I'm being forced to work on a reconstuted porta poty,a velocity, just so I can stay down here in the keys for the winter. Anyway, we are installing a IO540 and there is very little room between the mag and the firewall and we would like not to cut into that firewall. Any ideas would help..... Thanks
Old 11-23-2013, 07:19 AM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
Come back to Colorado. The cold will contract things enough & they will clear.
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 11-23-2013, 08:03 AM
vlittle's Avatar
vlittle vlittle is offline
You didn't say if you you had an impulse coupler on the mag. If so, you could remove it to gain some space. You'd have to make other considerations for starting, however. If you have an electronic ignition on the other side, that would do it.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 under construction
Old 11-23-2013, 01:54 PM
Impulse coupler!!! I'll check that out. Thanks
Old 11-23-2013, 01:57 PM
And Bill, you can keep that cold weather up there!!! The current temp here is 76 and a forecast low of 73. Keep shoveling.
