Old 04-11-2013, 06:25 PM
jrs14855 jrs14855 is offline
Default Fire
There was also the Rocket incident at San Diego where the pilot was unhurt but the airplane was badly damaged. IIRC also a loose fuel pump fitting. The AC style fuel pumps use a o ring type seal. The nut compresses this seal and prevents fuel leakage. If the nut is loose a significant amount of fuel will leak past the fitting threads. The fittings are straight thread.
If the fitting is a 90 or 45, you can try to turn the fitting/hose by hand. If the fitting moves the nut is loose. If the fitting is straight, you will have to put a wrench on it.
These should be checked at every oil change.
Old 04-13-2013, 07:12 PM
rzbill's Avatar
rzbill rzbill is offline
Originally Posted by Sig600 View Post
Does anyone know of an actual fire in an RV fwd of the firewall?
Yes, I saw the remains of an RV6 that caught fire due to a fuel pressure hose leak.
Firewall was fine but there was a BIG hole in the aluminum skin inder the pilots feet. I never met the gentleman but common friends indicated that his shoes were burned but he was OK.
As a result of that observation, I insulated my floorboards with the Mcmaster Carr ceramic batting discussed in other fireproofing threads here. Alternatively, a stainless sheet could be used for a few inches on the underside of the fuselage.
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 710hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 04-13-2013, 08:08 PM
DanH's Avatar
DanH DanH is offline
One piece stainless replacement of the RV8's aluminum ramp:
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-14-2013, 06:43 AM
rzbill's Avatar
I knew you had done some SS work Dan and thats why I mentioned it. I thought you had gone all the way across.
It has been 8 years since I saw that guys plane so memory can lie. I thought the damage extended to the corner of the fuselage but that would mean the cowl had to have burned away in that area instead of the flames concentrating in the cowl exit. I do not remember seeing the cowl itself because it was removed and my attention was on the firewall and fuselage.
Bill Pendergrass
Old 04-14-2013, 08:05 AM
dougmattson dougmattson is offline
Originally Posted by crabandy View Post
I bet it was one of these, I saw them in the conduit section and for $1.50 I bought a couple of sizes to possibly use.
These are probably not a good choice with the sharp edges. In the same department you can find chase nipples which are made to not chafe the wires. They are threaded for locknuts also.
9A flying
Old 04-14-2013, 10:33 AM
rv8ch rv8ch is online now
Default eyeball orientation
...Returning to firewall penetrations.....a steel eyeball with the open (hollow) end facing forward and filled with something like 3M FireBarrier 2000 ...
Hi Dan, This is a great idea - I had never thought about this orientation and I am just about at this point in my build. Regards, Mickey
Mickey Coggins
http://rv8.ch
Old 04-14-2013, 01:03 PM
DanH's Avatar
You're welcome Mickey. The 3M FireBarrier 2000 is intumescent, so even if the cable burns off the sealant will swell and fill the hole. Open side forward means if/when the silicone component chars, it will not introduce flame or smoke into the cockpit.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-14-2013, 08:37 PM
mcencula mcencula is offline
I bought several of these. Haven't installed yet.
http://www.averytools.com/prodinfo.asp?number=SA-05
There seems to be a lot of talk about stainless (especially with the TG-10). Does anyone know of an actual fire in an RV fwd of the firewall?
Yes. I am aware of one fire in an RV-10. The pilot made a great off-field landing and was able to walk away with only minor burns. Unfortunately, the airframe was a loss. I understand the tunnel floor was burned through even though the time of the fire was fairly short.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
Old 11-16-2013, 11:10 AM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
Default Dimensions?
Would anyone who has some or access to them, please give me the outer physical dimensions (the sheet metal) of the Van's options for firewall penetrations. I only need the bottom 2, I have some of the one-hole blue eyeballs.
GH
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 11-16-2013, 06:16 PM
GrayHawk's Avatar
GH
I may not need it. I found one document that looks correct:
http://www.doubleteeproducts.com/docs/7000_PIS09.pdf
bc
GrayHawk
